Why is my brake pedal so hard to push?
Discussion in 'The Garage' started by DPI, Feb 14, 2003.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    My brakes work well under normal braking conditions. However, when I really need to stop under heavy braking conditions, I can push the pedal down hard but it feels like I am meeting some resistance. I can only push it down so far and I don't have any more downward movement. The pedal is not down all the way to the floor, but I can't push it any further. My brakes seem to work very good, just curious if this is normal...
    Oh, I have a d60 and 14Bolt FFwith caddy discs in the back.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    What master cyl bore do you have ?
    Sounds to me like it's too big, but in putting those brakes on the truck, if anything, it should be too small. That is assuming it's what came on the truck.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Sounds to me like your booster is bad.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    The master cylinder and brake booster are stock. It also has the rear anti lock brakes.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    If the booster was bad, wouldn't the brake pedal be hard to push all the time?
  6. 79Beast
    Dec 9, 2001
    1,155
    Georgia
  7. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Check the booster vaccuum filter. Mine was clogged and I had the same problems. Checking this filter is the easiest and cheapest place to start. If only I had known this BEFORE I replaced the MC.
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks for the info! I didn't know there was such a thing. I will check that tonight!
