why is my dana 44 pegon toed?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Nov 4, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i lifted my 69 s.b. truck yesterday and the damn thing looks pegon toed! the top of the tires lean out, its identical on both sides. i lifted a ton of solid axle trucks and i have never seen this before, but most of the chevys ive lifted hve been like 79 and newer, does this old drum brake 44 have different camber settings? (4in lift, no shims) WTF. thx for any info--j.c.
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Is it open knuckle or closed knuckle d44?
  3. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    i dont know, i would assume closed, it looks like it has birfields?
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    It will be a closed knuckle front but not birfields.It has u-joints in the knuckle.Maybe the trunion(sp) bearings are shot.They have these instead of ball joints.
    chevrules...always has and always will
  5. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    I have the same problem. I replaacced all the ball joints and tierods. D44 can be adjusted at ball joints for front end alignment. mine wasn't really noticable with 31's. Really noticable with 35's. Localalignment shopsays that is cured with alignment.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
