why is my diff. leaking... from the top??
Discussion in 'The Garage' started by muddysub, Jun 11, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i swear it looks like my rear diff is leaking from the top of the cover! /forums/images/icons/shocked.gif the suburban is covered in mud right now and there is a line from the top to the bottom of the rear diff. cover that is clean and oily. /forums/images/icons/confused.gif what's going on?
  2. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    It may be that your pinion seal is out and it is throwing fluid everywhere and you have only noticed it on the top of the diff cover. Or maybe your truck is upside down and this is your way of saying you need a winch line. /forums/images/icons/shocked.gif
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If the pinion seal were bad would it CLUNK when put into gear, Mine started leaking and then started clunking... I'm going to replace it do you think it might fix the CLUNK or is the rearend starting to go.....?
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I got a similar leak...check the brake line junction at the top of the diff. That's where mine is starting to leak.
    Yeah, I know...another repair. My list is getting longer the more i work on it! /forums/images/icons/crazy.gif
    Rene
  5. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    Sounds to me that your pinion nut has backed off. You may be able to get by with replacing the pinion seal and torque the pinion nut to spec's. I would open it up and have yourself a look see at it.
  6. muddysub
    Jun 23, 2001
    10,451
    489
    i'm doing new ring and pinions (4.56) /forums/images/icons/wink.gif in july and my suburban won't be driven for the rest of the month atfer this week, i'll be in alaska.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Diff vents leaking, I'm pretty sure it's located on the upper right side (when viewed from the rear).
    Check the fluid, is it full of water (milky-brown), or just-plain over-filled? Is the vent hose plugged?
  8. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i ran into the same thing mine was the brake line junction might be a good place to start!?!?
  9. muddysub
    Jun 23, 2001
    10,451
    489
    okay i'll check the fluid soon. /forums/images/icons/shocked.gif thanks /forums/images/icons/cool.gif
