Why is my master cylinder throwin up brakefluid.
Discussion in 'The Garage' started by afroman006, Mar 6, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I recently replaced my master cylinder with a rebuilt one from autozone and now I have a leak coming from somewhere. I tightened the line fittings as much as I dare to but there is still fluid dripping from somewhere. It is a significant leak, after about a week and a half the front reservoir was empty. Judging by where the fluid is on the outside of the MC, I am guessing it is coming out of the top somehow. But I cant figure out why. Anyone have any ideas?
  2. Gixx
    Gixx Registered Member
    Feb 20, 2005
    8
    albuquerque,nm
    Check the gasket under the cap -
    You can bend the retaining bar "spring" some to cause it to apply more pressure to the cap. My rebuilt unit did the same thing...
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Plastic or steel resevior?
  4. afroman006
    Aug 21, 2002
    2,876
  5. divorced
    Jul 20, 2004
    5,115
    Not for sure, maybe the gasket at the top?
  6. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Same with my rebuilt unit. :crazy:
    Leaks from top. I inspected the reservoir and detected that the surface isn't machined well. There are small cracks and sometimes the upper edge measures less than 1mm.
    Obviously not a perfect seal.
    I'm thinking of an additional homemade gasket now . . .
    Regards,
    Walter
