why is my starter making that horrible jumping/grinding noise...?
Discussion in '1936-Present Suburban' started by Ddragggon, Jan 13, 2004.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    oh, because my engine is hydrolocked.
    -Rich
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    what happened?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Been there.
    Done that.
    Said the bad words. /forums/images/graemlins/wink.gif
  4. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Been there.
    Done that.
    Said the bad words.
    Ditto /forums/images/graemlins/smirk.gif
  5. Ddragggon
    Apr 25, 2001
    2,657
    my beautiful beautiful 250,000+ mile engine has had a `weeping' headgasket for a while. this headgasket has become worse and worse as time has gone by... apparently the final straw was me parking it out front of the shop, and topping the radiator off... came out after work to pull it in the shop, and tried to start it. she turned about 1/3 a crank, and then the starter began jumping off the flywheel, making horrible grinding noises. so, I tried to crank it by hand, to no avail... checking the radiator, I discovered it's about a gallon low, possibly more, and there's no water on the ground. I figgure at least one cylinder is near full of water.
    so, engine swap this weekend in a pre-mature sense.
  6. chvyhs
    Feb 12, 2001
    1,469
    Did you try pulling the plugs and spinning the engine?
  7. Ddragggon
    Apr 25, 2001
    2,657
    .... what, and destroy my excuse to throw a 454 in this thing?
    DON'T RUIN THIS FOR ME.
    even if it does free up, I can't have an engine that'll possibly lock and sieze at any given moment.
  8. Ddragggon
    Apr 25, 2001
    2,657
    The 454 has been pulled from the other suburban, and now awaits a thorough cleaning, new intake, and new oil pan gasket... VICTORY FOR ZIM!
    -Rich
