why is my transfer case lowered
Discussion in 'The Garage' started by deek, Oct 21, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I bought it like this, the case has been dropped 2" & i do have a 6" lift. I was just wondering if this is requiered, or could i raise it back up without any problems?
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    People often lower the T-case to help the driveshaft angles. It seems that eveyone's truck is different, some need it lowered for 4" to 6" lifts and some don't. I imagine the only way to know if you need it is to raise it back up and see. I bet you will get some u-joint vibration. /forums/images/graemlins/thumb.gif
  3. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    what degree of angle should i have? or what would i safely get by with?
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Put it back where it belongs and drive it. If you don't get any vibs your done. If you do you can drop it back down, but I wouldn't go more than 1".
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah it just depends on the truck, my neighbor's 79 k20 is lifted a good 6" if not a little more and it doesnt have the 203 dropped, so hmm..
    some need it and some dont
    good luck
  6. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Good thread /forums/images/graemlins/thumb.gif
    Im fixing to put a 6" lift on mine and I was wondering if I will need to lower my t-case. I noticed skyjacker makes a kit, but do I need to buy it? is there a free way to lower this 1" easily?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    DOnt buy a kit.. There are spcers above the frame on the bolts already so all you do is swap them under the frame.
  8. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,604
    556
    Wasilla AK,
    some times theres spacers and some times theres not especially if your trans has been out a few times those spacer tend to get lost over the years /forums/images/graemlins/shocked.gif
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Those spacers suck. Just big enough to work for street driving. Wheel it and you put a lot of extra stress on the frame. Makes a nice mess you break the frame because of them. Make or buy something w/ a bigger diameter
