Why is NP 208 weak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Jan 6, 2004.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Just wondering why the NP 208 is a weak t-case what parts usually break etc. It looks like that is what I will be using in my blazer
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I think most problems are related to its aluminum case. It is also a chain drive instead of all gear like a np 205. Other than that I dunno...
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    THe way the internals are setup is structurally weaker than the 241. if you go chain drive alluminum case, go 241
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Thats it in a nutshell. I've grenaded 2 208's, once while rock crawling and once while hill climbing. The aluminum is not all that strong. I do like the low gear in a 208, but the weakness of the case itself doesn't even out. Who knows, you might have a 208 that will out last your truck, I guess it just depends on how hard you wheel. I guess what I'm getting at is if you put any serious power into a 208 your looking for problems, if you wheel lightly then you will probably be good to go.
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    The onoly two weak points of the 208 are: (1) the aluminum case and (2) the slip yoke rear output. Yes, it is chain driven, but you will be hard-pressed to EVER find ANYONE that has had a chain fail on them. The chains fail about as often as gears in a 205 or 203. The aluminum case is a severe weak point. I have seen one of these crack climbing a ledge on a fairly basic trail before. The slip yoke is "weak" simply due to the fact that it is a slip yoke.
  6. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    So what's the best slip yolk eliminator to fix this "weak" point? (sorry for arrogating the post)
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You shouldn't have been rock crawling with a 208. /forums/images/graemlins/shocked.gif
    you said it yourself[ QUOTE ]
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would definantly go with a 241 instead of a 208. The 241 is a stronger sturdier case. The oiling system is also much better in the 241 and the low range is a little lower at 2.72:1 compared to the 2.62:1 208. I have a 241 swapped into my 85' in place of the old 208. You wan't to find an 89' 241 because it will have a mechanical speedo and swap directly into place without any modifications. /forums/images/graemlins/thumb.gif
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think the biggest weakness of any case with the slip yoke output design is when you combine the slip yoke with a lot of suspension lift. The slip yoke will take plenty of abuse with stock suspension because the slip motion is nearly linear with the output shaft due to the small angle of the driveshaft. Start lifting the suspension and the output shaft sees more side loading as you get higher. Add a huge side load to the binding of the splines under load and then compress the suspension suddenly... BANG! The case explodes. /forums/images/graemlins/eek.gif /forums/images/graemlins/frown.gif I'd bet that a 208 or 241 converted to a non-slip yoke would take a lot more abuse on a lifted rig. /forums/images/graemlins/thumb.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Hmm, maybe I should have done the SYE when I rebuilt my 241. /forums/images/graemlins/thinking.gif
    [hyjack] Do you think 7" of lift is a lot for a slip yoke?[/hyjack]
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    really ? so if i came across an 89 241 with 32 spline then it would swap right in place of my 208 in 83 with 465 ? what about adapter and outputs ?
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's getting up there! Take a look under your rig and imagine what kind of side load would be on the output shaft if you pressed straight forward on the rear of the driveshaft. The steeper the angle, the higher side loading is going to be. /forums/images/graemlins/frown.gif
  13. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    It was back in the days when I was 20 or so and I thought I knew everything. It was definitly a first hand learning experience that gave me some knowledge of why/where/how/when a 208 is weak. /forums/images/graemlins/thumb.gif
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    hmm, I'm not to sure on the 465, I was refering to an automatic.
    I know with mine the 208 and 241 adapters are the same behind the th700 and so are the splines with I think 85' and later.
    If I had to guess I would say that if the the splines are the same on both the donor 241 and the 208 then it will work and I would guess that the adapters are the same also. /forums/images/graemlins/thinking.gif
  15. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Ya want a 208 that looks like this one /forums/images/graemlins/thumb.gif
  16. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    what about a 208 with a skid plate for those rocky situations?
    (not to highjack this too)
  17. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    I am using the 208 because it is what I have I don't think I will have enough power to break the case. To whoever has broken the case did it break because you hit a rock or did it just split from torque input. I am very carefull when I wheel as I run 38s with a 10bolt frontend /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  18. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I had a skid plate under my 208's and I still have the same one under my 203. I haven't really givin any thought about a rock busting a 208, seems reasonable though.
  19. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I've been seriously abusing my 208 and 700r4 combo for some time now (since 95') to be exact. I run a medium duty Goodwrench crate motor that moves pretty well. I'm currently running a built 700r4 built in 02'. I have a great skidplate combo. I've never smacked the t-case itself. I've been told that it's a weak case by two tranny/t-case builders. I was also told that the chains don't really stretch and they are decent if you take care of them. I don't take care of mine other than armoring its mount (custom crossmember). I have an extra 208 ready to go in if this one craps it's pants... but I'm slowly starting to look in the direction of an atlas or maybe a doubler. (P.s. I don't have kids so I save my nickels and dimes for every new addition to my baby truggy).
  20. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    There really isn't an acceptable SYE for the 208. Some driveshaft shops sell a kit. This kit is essentially a new yoke that slips over the output splines of the 208 and bolts to the shaft. This requires drilling and tapping the output shaft; not an easy task. Then you use a telescoping driveshaft.
    Another alternative is to use a CV telescoping driveshaft with the slip yoke. When doing so, 99% of the movement of the slip yoke on the output shaft is eliminated. The suspension movement is absorbed by the telescoping driveshaft and the double cardan joints. This setup also helps to eliminate driveline vibrations caused by altering the stock geometry. If you are going to stick with a 208, I would recommend such a setup.
    A skid plate will help protect the case of the 208. I have never seen one split from torque. I have only seen a case split from sitting the truck on a rock (direct impact - resolved by skid plate) or from allowing the suspension to compress enough that the slip yoke jams into the tcase (resolved by CV driveshaft).
    At that point, the only other "weakness" is that if you loose your driveshaft (broken u-joint, busted axle, etc), the slip yoke will come out of the back of the tcase. That exit will soon be followed by fluid! No slip yoke = no tcase plug!
    Hope this info helps ya!
