Why is the rear track width less than the front?
Discussion in 'The Garage' started by jimmy88, Sep 2, 2002.
  1. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Is there a functional reason for this?
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I've been told it's for better turning radius. I've also heard that GM figured it would provide better traction if the rear wasn't following the same ruts as the front, but this story doesn't sound probable to me.
    Rene
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ] One of the great mysteries of life. /forums/images/icons/crazy.gif
  4. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    Think the F550 Turtle Expo truck had custom rims to make the track widths match, so other manufacturers do this. Turning radius, maybe since you pivot off the back tire, but at something like 1.5", how much can that change it? Traction, I agree with you, that seems thin.
    I'm asking because I am thinking of spacers so the back tires follow the fronts. There have been a few times where the front went over a rock and the back slid sideways off it and clipped the rim. (you know, with the J**p trails you don't get too many choices for the right line)
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    lol good question, i read this post and ran out and eyed my trucks tires from front to back, and back to front, and sho' anough the fronts stick out wider then the rears, and they both 10 bolts /forums/images/icons/grin.gif go figure, i belive it is for a better turning radius, that story sounds better to me, or for handleing purpoeses, never found it useful off-road /forums/images/icons/wink.gif
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea..some people use spacers in the rear to get them to match..but its really not that big a deal to me..i dunno..
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have different backspacing on mine to make them the same 3.5" in front and 2" in the rear. I cant rotate my tires, but it is a trailer queen anyway. I seems to make it much more stable that the other way and the custom offsets only cost 40 bucks so it was way cheaper than buying spacers.
  8. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    It really is for traction purposes, kinda hoaky but true. The theory is that you will use your sidewalls for the added traction in the mud. This does work, otherwise why have side lugs and side biters on tires. As for the whole turning radius thing, it actually widens your turns by a little bit.
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Actually, I think if the rear was wider, the turning radius would be more.
  10. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    I know it goes one way or the other, I thought it was if the front was wider so is the turn, but I could be wrong. It's been a while since I've read about it.
  11. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You're on the right "track" /forums/images/icons/grin.gif
    That's what every GM experienced wrenched has told me.
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The rear track width will affect both the overall turning radius of the vehicle and the handling (such as oversteer and understeer). The narrower the rear track width the sharper the turning radius, and I believe the more oversteer the vehicle will exhibit.
    I'm pretty sure it has nothing to do with traction in ruts or mud.
  13. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It's a scam propogated by the wheel spacer companies!!!! /forums/images/icons/grin.gif
    Now that I've got my truck setup with the same track width (front and rear) it looks WAY better.
    On a lifted truck, anything you can do to increase track width is going to help to add stability too....
  14. Grim-Reaper
    7,385
    Atlanta
    The new Turtle was a dually. The rims were to address that.
    The priciple is for tighter turning radius. In snow the different track would work to your advantage.
    The track width has been a pain when your dealing with stuff like big V-Rutts. You put the front wheels where you need them but the rears can't follow the same line and slides in dragging the front with it. Happend to me many times.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Triaged should be able to explain the reason suspension guys want wider front track
    no idea if chev truck engineers did it for a good reason
  16. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think Chevy did it so they could use the same rear end in a 2wd and a 4wd. They had to make the front wider to give the front wheels room to turn. And they made the front of a 3/4 ton even wider to clear the brakes etc and still use the same axle housing. I think the whole thing was what was the easy way to do it, not the best way.
  17. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Why, then, are van axles wider that truck axles??
  18. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Because they're van axles. The width of truck axle has been fairly stanard for years.
  19. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Call me funny but I thiink it was for stability in turns. over the last 20 years consumers have been asking for a truck that drives like a car. By widening the front axle ( the one which has the sway bar on it, hint, hint) you gain a better cornering at speed feel. When they went to the independant front they widened it some more and now those truck feel more like cars. /forums/images/icons/smirk.gif And of course it does allow them to use the same axles. However I know that the late 60's and early 70's truck ran an even narrower rear then what was in the late 70's to the 90's trucks. But my contention is the high speed cornering. /forums/images/icons/cool.gif
  20. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Ever riden a 3 wheeler?
