WHY ME!!!400 issues
Discussion in 'The Garage' started by jones, Feb 27, 2007.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    No,I don't have 400 issues..just issues with my 400 sbc.thought I'd clarify.
    Anyway,after having my truck sitting for a year and getting a heart transplant,and solving my timing,no start,electrical problems,I've been experiencing bad vibrations, and rough running.After using the search function,I realize that I get to pull the engine again.
    I didn't know at the time of the engine swap(350-406)that the 400 block uses an externally balanced flywheel:angry1:.:doah: I guess I should've researched the swap a little more.
    So,the question is,what kinda $$ can expect to pay for a flywheel for the 400?Is there any specific brand,etc?thanks,guys!
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Get one from auto zone. It's made by pioneer and it's held up to a lot of abuse from me! It also accepts the large clutches easily. I can't remember what i paid... I wanna say about 150?
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The harmonic balancer is also exclusive to the 400 in case you swapped over anything other than a 400 balancer.
  4. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    hay
    you can get a plate that bolts on with the 350 flywheel from kurt at diy 10 bucks maybe hes in the vender section cyberfire allrighty then:D
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I don't like those because they move the flywheel out of alignment for the starter to engage properly and i also don't think they are compatible with a flywheel, only a flexplate. I'm just going by what i've read somewhere.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    I got mine new from GM and I think it was less than $100. I got the employee discount at the time but that may be one option to look at.
  7. jones
    May 17, 2004
    379
    IONIA,MI USA
    The Zone is looking like my only option right now.Napa only has the insert.$92.99 for the flywheel,$61 for the insert.other parts stores only have the ring gear.
    The 400 was originally backed by an auto(350/205)it has the correct harmonic balancer.
    So which do you think would be easier to do?pull the engine,or the trans.?
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    pull the trans
  9. jones
    May 17, 2004
    379
    IONIA,MI USA
    I e-mailed Kurt at DIY. He didn't see any reason it wouldn't work.Says it's only .070" thick so it shouldn't have an effect on the starter engaging.So I may be the guinea pig on this one.We'll see what happens.Thanks guys.
