why my steering sucks!!!
Discussion in 'The Garage' started by 96chevysfa, Feb 24, 2004.
  1. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    ok, heres the scenerio, im running 36" tires, dana 60 front, jkw crossover steering arm, 1 ton DRE's, and have very litle angle on my draglink, and stock steering box.
    my DRE on the pitman arm does not last, it keeps getting play. ive replaced them 3 times in 4 months, and my last set has lasted me a whole 3 weeks and now my steering is very loose, and i know its the DRE, you can see the play when you steer at a stop. is there a better option to use besides these DRE's that isnt gonna cost a fortune? and why dont they last,
    here are some pics of my steering setup.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Angles look pretty good maybe heim joints? Not real familiar with all the joint stuff but TTT for ya.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm using the big TRE's and have had no problems at all. Bought them from ORD.
  4. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    whats the deal with the bottom pic?
  5. 96chevysfa
    Jan 1, 2003
    230
    so cal
    oops, linked the wrong pic, ill change it
    i took video of the movement, but it was too dark int he vid tor eally see, ill take another one tomorow.
  6. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    I notice you are using the rear hole on the steering arm. Are you sure this is the hole JKW intends to be used for crossover and not for the tie rod in hi-steer applications? ORD for example intends for the front hole to be used for the draglink and the rear for the tie rod.
    This would give the steering box more leverage against the wheels, and may take some load off the TRE? just a thought. /forums/images/graemlins/thinking.gif
  7. 96chevysfa
    Jan 1, 2003
    230
    so cal
    it would take some leverage off the box, but then i wont have any steering radius, maybe its just time to get hydro asist... hmmmm
  8. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Have you tried it in the other whole yet??? Maybe its not that bad... Although... hydro assist is cheap. /forums/images/graemlins/peace.gif
  9. 96chevysfa
    Jan 1, 2003
    230
    so cal
    i have trie dthe other holes, and the radius sucks in all but the first.
