Why no detroit locker in a 14FF with Gov-loc?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GUMBY, Jul 12, 2001.
  1. GUMBY
    GUMBY Registered Member
    May 17, 2000
    35
    Alabama
    What is the physical reason why a 14FF with a gov-loc can not be fitted with a detroit locker? Is the carrier a different shape or something?
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Gumby-The detroit locker made for a 14 bolt is made to fit inside a stock "open" carrier. If the truck already has a gov'loc in it, the gov-loc itself is made different than the open carrier and you can not install the detroit inside it,( no room)
  3. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    can you replace the gov-loc carrier with an open one?
    Email: xiaozhu@my-deja.com
    ICQ: 84108805
  4. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    The reason a detroit locker wont go into a gov-lock carrier is, a gov-loc has three anti-rotation post in its carrier were a detroit locker requires four post. Go to the junk yard and find a 14 bolt FF with a open carrier. The cross that holds the spider gears will have four post. Hope this helps.
    MAC
  5. GUMBY
    May 17, 2000
    35
    Alabama
    Thanks 4xmac and Steve.
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    FYI, the gov-lock is rebuidable, and the detriot is not.
    Some may debate the strenght of the gov-lock, vs. detriot, but for your application it may not matter.
  7. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i agree with executioner, it is a lot stronger than your garden variety 10 bolt gov-lock. totally different design. not a bunch of little parts to get abused by big tires and power. mine is awesome as hell. if i do a power break at a stop light, and keep the power applied through a corner, it will chirp....it locks tight as hell. just remember where these axles came from (3/4 and 1 ton trucks that are used to carry tons of weight). i will run it till it goes, but as good as a detroit sounds, it may be cheaper and easier to just rebuild the gov-lock. i am very surprised with its performance...
    later rob
    c:\program files\ulead systems\ulead photo explorer 6.0\cache\img00010.jpg
