Why not go with 4" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86K5, Jul 5, 2001.
  1. 86K5
    86K5 Newbie
    Jul 5, 2001
    Why not go with 4\" lift?
    I'm debating between the Pro Comp 2.5" lift and the 4" lift. I have an '86 blazer with 33" tires on it. I don't plan on going to anything larger than the 33's. I'll be doing moderate offroading, not serious rockcrawling. Is there any reason NOT to go up to the 4" lift, instead of the 2.5"? My main concern is that I do not want to have premature driveline problems or any other mechanical complications. I can live with the harsh ride, but I don't want to give up any reliability.
    Thanks!
    <P ID="edit"><FONT SIZE=-1>Edited by 86K5 on 07/05/01 10:06 AM (server time).</FONT></P>
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Re: Why not go with 4\" lift?
    With the 2 1/2" you would not have to get longer brake lines or a raised steering arm. But personally I would go with the 4".
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</A>
  3. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I would go with the 4" lift. You need a raised steering arm. And some people here have needed a longer front drive shaft. Besides that, I have had no problems with mine. I was running 35's with minor trimming and no rubbing.
    That's because I'm the devil.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    yeah if you get the 2-1/2 you'll probably wish you'd gotten the 4". The 4" is pretty versatile...you can run 33's or 36's with some cutting. It's a good all around lift. Plus the shackle flip is easier to do homeade style!
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why lift it any higher than you need to? The higher the lift the more problem$$$$$ you will have to fix.
    Resale or trade in value on lifted trucks sucks. Insurance is an issue because the vehicle is modified. Insurance companies are getting to where they dont like to cover modified trucks. The higher the truck the worse the gas milage. A lifted truck rolls over easier. They don't fit in a garage.
    I'm not saying lifted trucks are bad. You asked for reasons not to go high.
    <font color=orange>GOT HORSEPOWER?</font color=orange>
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I've got 4" with 33's. And it all fits together very well. Im still going to trim the fenders a little though. If I dis-connect my sway bar my front tires would rub if turned and flexed at the same time.
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    You may not want ot get the 4" if you have a really short girlfriend who hates climbing up into your ride. :)
    If not, go 4"!!!!!
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    No way Mike... That is when you gotta help the short girls up into your truck [​IMG] LMAO [​IMG]
    Well I would go for the 4". You say you only want 33's, but lift and bigger tires are contageous... I was thinking of a 4" lift but went w/ 6" and now I want more [​IMG]... maybe body lift and trimming to run 38 swampers [​IMG], and I'm not a real hardcore offroad guy eitherLOL. But I would go 4"... cause like lake tex said... very vesitile... run 33's w/ no hassles or trim the fenders and go 36's.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  9. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i just got a pro comp 4" and put it on my sub, its easy replacing the steering arm, so it's no big deal, and the leaves are pretty comfortable on the road. haven't hit the trail yet, need new lines. it was fun to install cuz it was my first one, but it was rather easy. the only prob i had was the springs i got were for an '87 and earlier sub, but the guys at four wheel parts were cool and they got me some new larger bushings for my '89. ( the shackle bolts are bigger on my sub than an older one). i think youll be very pleased with a 4".
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 35s, tbi350
  10. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    I had that problem for a while. But I rather liked it. Giving her a boost up, that is.
  11. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I'm running a 2.5 on my 83 with 35BFG's, I think it needs a raised steering arm. But anyway I plan on going to a 4in and I don't do the hardcore wheelin anymore. I just like the look of the 4in lift, yes you'll have buy somemore stuff for your K5 but your going to anyway right?
    Lost? i'm not lost i'm just disorienated
    Cethern@interfold.com
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    They're both the same price, right (kinda sorta)? Just go with the 4", I got the 2" lift and I kind of regret not getting the 4" now. I did the shackle flip and had to remove a leaf from the rear springs to make it look normal.
    "My blazer may be slow, but it goes faster at higher speeds"
    <A target="_blank" HREF=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</A>
    Jim
  13. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Doesn't ORD make a 2.5" flip kit?
    '71 Blazer CST with alot of rust
  14. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yes they do <A target="_blank" HREF=http://www.offroaddesign.com>http://www.offroaddesign.com</A>
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go 4". If anybody takes any of my advice from this site, do this!
    I first went with an add-a-leaf from JC Whitney and a 3" rear block. It did look good compared to stock, and it was only $70.
    However, I got sick of it after 3 months and ripped it all apart again and went 4".
    I've since given it away to my friend. $70 wasted. He got it, I helped him put it on, and it looks good with 33s, but I still think a 4" is better. That's why there's a 4" on my truck.
    Tim
