Why NOT to buy 16.5" rims (pics inside)
Discussion in 'The Garage' started by TruckNutzDude, Dec 31, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Why NOT to buy 16.5\" rims (pics inside)
    This was at 25psi. at midnight in a mud pit. I had to drive on the rim for a couple hundred feet before I found hard enough soil to mount up my spare... I'm glad I bought the BIG hi lift jack /forums/images/graemlins/thumb.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Re: Why NOT to buy 16.5\" rims (pics inside)
    personally i scrap all 16.5" stuff i come across, i dont believ ein 16.5" at all, i keep and use only 15" or 16" stuff, im glad my 83 came with 16" on it /forums/images/graemlins/thumb.gif
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I got all 5 tires for $150 so couldn't pass... I sold them and got what I paid back shortly after these pics were taken.
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    HEy...don't be dissin' the 16.5's!
    They're Not ALL Bad.
    I TRY And I TRY...but WHY can't a Peel them off??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    Agreed, if you don't have 'locks, I wouldnt touch a 16.5 with a big stick.
  5. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    if you can find some aluminum whls the tire will stick better to the aluminum than the steel whl,
    i used to run 10 pounds on a 16.5 whl ,40'' bogger,
    only had problems when i went down to 8 pounds.
    15 '' beadlocks now though,
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    oh ha ha. If I had those rims I'd run 16.5's too /forums/images/graemlins/grin.gif
  7. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    I don't know, mine have been down to 5 psi already and no troubles. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    guess you got ta lock em...
  8. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    At 5 psi I had 2 tires pop off the rim without moving the truck at all. /forums/images/graemlins/frown.gif I had a slow leak and forgot to air them up before work one day... came home and had to put 2 tires back on the rim /forums/images/graemlins/rolleyes.gif
  9. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    16.5's are an interesting nut in the box of chocolates, pretty good tire availability, the only wheel available for some combo's, they fit over big brakes, etc, BUT you can't really air down without beadlocks. That's just the way they are.
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    heres a funny story:
    back when my dad first got out 78 burb it had 32" coopers on 16.5 rims. My brother an I took it to the coast and ran the tires down to 7 PSI...yes 7 PSI on a 16.5 rim... we ran all day cutting donuts and everything with no probs...YET.
    go to part the rig out 2 years later and with a tire low in the dirveway it rolls off the bead just in the driveway,LOL!!!
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Run stock 7" wide ones. They are cheap (read used), common, and a 15" wide tire has a hard time popping off without popping right back on. There is some slight tire wear issues in the center, but hey, we all have issues /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  12. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    nice looking beadlocks.
    I have 16.5's . Lowest tire pressure I've gone to 15 psi. Whenever I do get new tires , I'm switching to 15"
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    cybrfire is burning me a custom set for my wagon.. only way to run 16.5s ...Locked!
  14. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I can't justify the price of bead locks when a 15x10 wagon wheel only costs about $40. A little time (few hours) with the angle grinder, a few discs and I MIGHT have $200 invested in all 4 of my wheels. Putting bead locks on means $200 per corner /forums/images/graemlins/eek.gif Bead locks are sweet though and I'd have a set if price wasn't a concern.
  15. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    ive never had problems with my 16.5s yet.had em on now for 2 years aired down to 15psi and rockcrawled no problem.i wouldnt go down any lower than 15 though just in case.the 45 degree bead just isnt good enuf to hold the tire in a high wheelspin or high torque on the tire situation aired down.why is it that the only rim that has the 45 degree bead comes standard on a lot of trucks.
  16. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Price was a concern for me too, but I ended up finding some 8 bolt hummer rims for $15 a piece(bought 15 of them) and I found some magnesium ruflats on this website for $22 a piece shipped. So I am into my dual beadlock 16.5 rims for $185 and that's for 5 of them. If you are patient you can find lots of 8 bolt hummer wheels for cheap, and there are runflats popping up because some people are changing to the PVC ones. Not sure why though.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah but then you run into the backspacing issue.
  18. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Another thing you can do with 16.5" rims is wrap a 1/4" rod around the edge of the wheel. I've never done this myself but I hear it helps retain the tire. I guess like building up your own safety bead.
  19. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I never thought of doing that. It would be fairy easy since I work in a machine shop and have access to 1/4" rod and the equipment to bend and weld it. I might have to try this sometime in the winter. Thanks for the tip.
  20. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Would adding the 1/4" rod to the wheel affect mounting and dismounting tires?
    Where would you put the 1/4" rod?
