Why Now????
Discussion in 'The Garage' started by bee32, Apr 16, 2003.
  1. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Okay, While I was drivin home the other night after wheelin with a bud to test his 4x, My brake light came. Now I have noticed my brakes being alittle squishy. There is fluid coming from the rear left tire on the inside and it appears to brake fluid and not Diff oil. Thankfully! What seal is leaking in there? It is a drum brake on ten bolt. I know there is a seal in there but what is it called. I want to fix this prior to Tellico.
    Question #2: I installed a dual steering stabilizer over the weekend and seems to be kinda makin a poppin noise when I turn. It doesn't do it while sitting still and I have full travel. Everything is tight. Any Ideas? I might add that I added a rock slider on the driver side and I thaught that was making the noise but there are no rub marks on the Body or the rails where it is close to the body. And I repaired a bunch of cracks on the forward frame. Maybe it just doesn't like being all together /forums/images/graemlins/rotfl.gif. Thanks fer any advice on this.
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll second the wheel cylinder.
    As for the pop, check your body mounts. Since you fixed some cracks, it stiffened the frame, now the body prolly moves around a little. New mounts are most likely in order, as some new bolts.
    John
  4. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    Thanks! I do appreciate it.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The popping is the frame flexing turning the tires. You should think about bracing it up in addition to what you have already done to the cracks. I would fix it sometime soon my buddy tunings 38's ripped his box off one day. I haven had any problems, popping, nothing, and im turning 42's. I made a custom brace for the frame. Works great!
