WHY: One exhaust tip burned, the other not...
Discussion in 'The Garage' started by ErikH, Jul 20, 2002.
  1. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    I recently replaced the tailpipes on my dual-exhaust with shorter exhaust tips that essentially turn down n' out behind the mufflers. All is good, but I noticed that one tip is all blue and black from heat, while the other is not. Why would one side be hotter than the other? The engine seems to run smooth, but do I have a problem?
    -Erik
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    do you have one or two mufflers? If its one, it may be that the muffler flows that way, if two, there could be a problem
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    he said he has duals there....
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    could be an air adjustment? One side burning richer than the other. Mine did that after I broke my piston. Could be a vacuum leak also causing it to run rich on one side.
