Why stay diesel?
Discussion in '1982-Present GM Diesel' started by ramack, Jun 20, 2004.
  1. ramack
    ramack Registered Member Premium Member
    Jun 20, 2004
    72
    5
    Centennial, CO
    Ok, I need some pros/cons for diesel....
    This is my situation.
    I bought a '77 K5 when I was in Colorado at a very good price. It has a 350 4spd and that's the main reason I bought it. I used it mostly for hunting, fishing and camping. I now live in Mississippi and with the higher humidity (from 15% to +90%) the already rusted body is worse and won't pass inspection.
    I've come across a '83 K5 with a much better body, but it has a 6.2L diesel with an auto trans. I'm planning on doing a body swap unless someone can convince me that the 6.2L is worth keeping. Presently it doesn't run, but I'm told will run if the starter is replaced and mounting bolts/threads are repaired.
    I don't do much towing, and will continue to use it for hunting, camping and ocassionally some light muddin'. In the mountains I had this thing on angles and bouncing around that the carb flooded out. Besides that torque and it's tough to kill a diesel once started, those are the benefits of the diesel.
    Any input is appreciated.
    Rich
  2. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    1) fuel mileage.
    If you don't like diesels then it may be hard to justify. I would try to get it started and see what you think about it. Maintenance wise its similar to a 454, 7-8qts oil-same filter. Fuel filter is a little more, air filter needs changing a little more often. Glow plugs will last longer than spark plugs, if quality ones are used.
    Reliabilty wise, crap shoot. I've seen more 350s with 200-300K+ than 6.2/6.5s.
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Double the fuel mileage or better and it is way better off road. No brainer IMO.
    Rene
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
  5. ramack
    Jun 20, 2004
    72
    5
    Centennial, CO
    Is there any problem swapping out the auto tranny w/overdrive with my 4 spd from the '77? Can it handle the torque? I'm guessing that if I use the gas 4spd, I would need an overdrive with a diesel.
    Rich
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You can use that SM465 behind the diesel. It is the same 4 spd that the factory put behind them. My personal preference would be to run the 4 spd behind the diesel as it will hold up better and last longer than the 700R4 auto that is behind it now. The early 80's 700R4's are very weak in factory form (but has probably been replaced in the past on a 1983).
    As far as OD gear, for highway cruising you would benifit from adding an overdrive to the SM465 but weather or not the added cost would be cost effective will depend on your use of the truck.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The SM465 can handle the torque way better than the 700R-4 ever could. As for needing overdrive...couldn't hurt but it's not necessary. The 6.2 is just as happy cruising at 2700 rpm as it is at 1900 rpm. You'll just gain a few more mpg with overdrive.
    Cruise rpm on my truck is 2600 rpm and it still gets 16.2 mpg on the freeway. It's not much worse in town...roughly 15.5 mpg.
    My 6.2 installed:
    Port matched and polished intake:
    Wheeling in Moab (I'm in a pic posting mood LOL)
    If you need a pic of anything in particular let me know...I got me a new digi-cam and the Jimmy is only 20 feet from the puter. /forums/images/graemlins/woot.gif
    Rene
  8. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    What no Chevy engine red ?
    Better fuel mileage.
    Less crap to worry about.
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The red 6.2 was only 82...after that they were all black. I chose "GM corporate blue" for mine. /forums/images/graemlins/dunno.gif
    Rene
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    does polishing the intake to match the ports make that much of a difference? If it does, I want to do it too. /forums/images/graemlins/smile.gif
  11. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Do the body swap, and give me the vin/ rest of frame/engine/ etc. I'll be more than happy to take it off your hands!
  12. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The intake ports were over 1/4" smaller than the gasket opening and the ports in the heads. I was astounded at how poor the casting was. I used a carbide burr on an air powered die grinder and it took me about an hour to do.
    Anyways, I changed injection pump and injectors at the same time. The right foot dyno noticed a difference...
    It's an easy and cheap mod, not much to lose but a bit of your time to do it.
    Rene
  13. ramack
    Jun 20, 2004
    72
    5
    Centennial, CO
    The flat tow has begun! Can't wait to get this thing home and began to inspect it closely. I believe the frame is bent, so I'm most likely proceeding with the body swap with my '77.
  14. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
  15. 82diesel
    Jul 2, 2003
    316
    Stockton, CA
    did not know that.
    looks good mine is half red and half grease/oil
  16. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The top half of mine is blue, the bottom half is black and wet...gotta do a rear main seal soon /forums/images/graemlins/crazy.gif
    Rene
  17. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Wow!
