Why won't it run?
Discussion in 'The Garage' started by 89GMCSuburban, Sep 9, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Why won\'t it run?
    I have a 67 C10 with a points distributor on a 350 out of an 80's van. It was running badly with a miss, now it won't run. Power tests good through the coil, the cap and rotor are a couple of months old, but no spark is getting to the plugs. Points are new with dwell set correctly. Wires are brand spanking new. What could the problem be????
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: Why won\'t it run?
    did you check the condensor?
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    do you have power to the points?? is the coil bad??
  4. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    check condenser wire and see if it may be making contact and grounding out.
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Condensor is new...
    Power is getting to the points...
  6. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Coil is new...
  7. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    If you get spark at the coil wire,but not to the plugs--its got to be the rotor or cap,check carefully for carbon tracks or cracks--I've had some that looked absolutely perfect,yet the car wouldnt start till I replaced them.If you got no spark at all,even with new points and condensor and coil,and you have power to the + side of coil,you may have a sheared roll pin on the distibutor drive gear--its /forums/images/graemlins/angryfire.gif rare,but I found one after many days of frustration on my friends 250 6 cylinder--it would run perfect,sometimes for days,then suddenly backfire and stall,after several cranking attempts it sounded like it had jumped time,then it would crank normal and start right up--seems the gear would slip on the shaft intermittently,allowing the timing to move,then it would go back to the right spot and run awhile longer. Roll pin cost 60 cents---we replaced everythimg but the gas tank trying to fix it,spent 300 bucks for nothing!! /forums/images/graemlins/angryfire.gif
  8. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Hey, I didn't think about that. Looks like I'm gonna be pulling the distributor....
  9. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Rotor is turning... I see no grounds coming off the engine to the frame or firewall. That's bad, right? The only ground is from the battery to the alternator bracket...
  10. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    BTW, new cap and rotor, still won't start...
  11. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    TTT, Anyone???
  12. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Bad coil wire? From cap to coil. Or not plugged in all the way. /forums/images/graemlins/eek.gif
  13. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Nope... /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
  14. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    It could be the timing is 180 out .usally it would start though but run like crapola
  15. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Can't be... never even loosened the clamp since I got it 4 years ago. This just started last month...
  16. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Do you have fuel?
  17. RustBuket
    Feb 21, 2003
    1,618
    Ok, nm I see that you said you have no spark to the plugs.... Which in that case, I don't know!
  18. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I looked through the posts, you did not mention if you have spark at the coil wire, do you?
  19. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    How do I test power out of the coil into the cap???? My uncle tested it and said there was power, but I'd like to double check, you know?
  20. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    The only idea I have is the ole drill bit trick. The one between the coil wire and the distributor cap and then clamp the positive lead of your voltmeter to the drill bit and the other to ground. Hope this maybe inspires someone else. Good luck.
    Allan
