why wont my truck start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Sep 5, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    my blazer died on me last week and i have no idea why. I changed the cap and rotor bc they were totally shot, and it still wont run. Can you guy give me some options? I know its not fuel...im not getting any spark to my plugs.
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Checked your ignition module, coil and associated wiring?
  3. blwnbwtie
    blwnbwtie Registered Member
    Jun 4, 2002
    72
    LA California
    asuming that is hei which it most likely is make sure that the coil is the right one for your cap. there are two different coils and if you mix em up it wont work. Also watch out for the aftermarket stuff. My truck has that stupid huge accel cap and coil and i tried to switch the coil and use it on the same cap and it would not run.
  4. 73 Heavyd
    73 Heavyd Registered Member
    Jan 28, 2002
    38
    South Dakota
    Second the ignition module. If it was running even halfway decent then just died, check the module. About $20-25 to figure it out.
