why wont the front axle engage?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sinchphoto, May 24, 2002.
  1. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    10 bolt front with auburn and manual hubs.
    when i punch the gas the front axle only spins for a second or two and then NO MORE.
    the transfercase is still spinning the front driveshaft but the front tires wont spin. we put the truck on a pile of sand with the tires on top of it and thats how i was able to see all this.
    Bad hubs? not engaging right? any thoughts guys?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sounds like bad hubs if driveshaft is still spining.
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Sounds like the hubs aren't engaging properly.
  4. Grim-Reaper
    7,385
    Atlanta
    Uhhhh With a auburn it should at some point engage both axles. One bad hub I could buy but two bad hubs sounds weird unless assembled wrong or cheap ones. I'm leaning towards a blown auburn or a stripped ring and Pinion on this one.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    487
    Grand Rapids area
    Look inside the knuckles to see if the axle U-joints are spinning. If so, it has to be the hubs. If not, look for a broken Auburn or teeth missing from the ring and pinion.
    Also, are you sure that all of the parts are correct and that they are assembled correctly? If you use the wrong axleshafts, for instance, or have the hubs installed incorrectly, you could get a problem like this.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Isn't the auburn a posi? With a posi don't you need some engagement from one side for power to transfer to the other side? If one hub is bad then will power still transfer to the other side? Not sure but???
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd say pull the cover and look if you can see anything broken. Jack it up (tires off ground) have someone spin drive shaft while you see if knuckels are rotating. Good luck, hope you get it fixed soon with out having to spend too much on parts.
  8. tagurit
    tagurit Registered Member
    Mar 19, 2002
    25
    Nth E. Louisiana
    I hate to seem dumb, but where/ what are the knuckles you speak of?
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Knuckles are the part that Pivots on the main axle tube, on the outer most part of the Main axle housing it kinda comes to a "C" the knuckle is conected to the Top and Bottom part of the End of the Axle house "C", let me know if i explained it so you can understand,
  10. tagurit
    Mar 19, 2002
    25
    Nth E. Louisiana
    then the knuckles are on the outside of the axle tube near the inside of the brake drum?
    I'm not too "in the know" when it comes to the underside of the truck.
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    drum? your talking about the front end right?> should be a disc
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Yes. But you should have disc breaks on your truck.
  13. tagurit
    Mar 19, 2002
    25
    Nth E. Louisiana
    yes, I do have disc brakes on front, haha... I just didn't know what to call the backplate of disc brake system.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Automadic locking hubs, anyone have any idea why it's not engageing ????? I don't know muck about the auto locking hubs.
