Why would I take out the sway bar?
Discussion in 'The Garage' started by google, Jun 17, 2005.
  1. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    I was reading the differences between rear spring and block lifts and found something that makes me have to ask. Why would you take out the sway bar when wheeling?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    it gives you much better axle articulation. each tire can move indepently easier
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    the job of the sway bar is to keep the axle as level to the body as it can. The idea of offroad articulation is the opposite, thats why.
  4. mr_blasto
    mr_blasto 1/2 ton status
    Nov 8, 2004
    495
    Irvine, CA
    I have a '72 that does not have a sway bar. That being said, I have some experience with sway bars on other cars.
    Sway bars are very useful under cornering because it limits body roll. When going around a turn the outside suspension will compress (or bump) while the inside will want to unload (droop). A sway bar ties the sides together and resists twisting. So as the outside tires try to tuck that force is going to be distributed to the inside tires as well forcing them in the tucking direction. Simultaneously as the inside tires try to droop, that force is distributed to the outside tires resisting the tucking/compression/bumping movement. So the sway bar reduces body roll by resisting the inside tires downward movement in relation to the body, while resisting the outside tires upward movement in relation to the body. Some body roll still occurs as the sway bar twists. Want less body roll - get a sway bar that is stiffer (usually larger diameter). Anyone see where this is going?
    Sway bars are designed to reduce articulation, as explained above. In desert racing, with trophy trucks and all that, body roll and high speed turns are a huge concern, so sway bars would seem very neccessary. With rock crawling, they are severly limiting.
    Obviously I think I am right... but I don't have hands on experience with sway bars on a solid front axle - feel free to correct me
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    If you do crossover steering in front, your swaybar will no longer fit. If you stay with the stock steering setup, I'd leave it on and get some quick disconnects for it if you are a rock crawling type of wheeler. If you just trail ride, I'd just leave them on.
  6. mrk5
    Apr 20, 2004
    12,338
    1,045
    Northern Colorado
    I've left my swaybar on to help clear 37s with 2.5" lift.
    That being said, eventually I may do crossover and move the axle forward with a 1" zero-rate. That will require disconnecting the swaybar, and I don't plan on shedding any tears.
    I did a poll on this a while back and got a lot of response. Unfortunately when the forum was upgraded the poll disappeared, but you can see from the replies how a lot of people feel about keeping them. The poll was overwhelming for removing them. It was like 80+ for and 30+ against IIRC.
    Click-->Sway-bar poll
  7. google
    May 19, 2005
    805
    Arizona
    You can move your axels forward???? Ok, I'm gunna hijack my own thread... How the heck do you do that?
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Longer front leaves will move ur axle forward but that requires custom spring hanger mounts etc. U can also get offset zero rates to fit between the axle and the spring that move it like 1.5" or something.
  9. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    I took my sway bat off of my 73 daily driver with 4" lift. this truck does not see high speeds. Only a few times have i took corners fast enough to be bothered by not having my sway bar. On the trails with 35 all terian tires i feel that my tires stay on the ground better than with the sway bars. Why would rock crawling or trail riding be better with a sway bar? I do notice when hauling heavy things that there is a difference with the sway bar gone.
  10. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Sway bat? :haha:
    Sorry couldn't resist. :surepal:
  11. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I redrilled the spring perches and spring plates...moved my diff forward 1.25".
    Rene
  12. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    My truck rode soo much softer with the sway bar removed. With lift springs the sway bar is misaligned and will cause binding as the suspension moves up. You can eliminate that by running ORD's quick disconnects, the disconnects links move the sway bar up.
  13. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you take it out, don't you loose trailering ability?
  14. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I think it depends on how soft the front springs are. I'd also think there wouldn't be much reason to remove the sway bar for a Tow rig. If it sees double duty, then I'd run disconnects.
    Rene
  15. Camorokkrwlr
    Camorokkrwlr Registered Member
    Feb 11, 2005
    23
    reno nv
    you left it on to help clear 37's????? :confused: a sway bar does nothing but control body roll
  16. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    It limits articulation, therefore he doesn't run much. Although with the body damage he's been getting lately, I see a LOT of trimming in his future... :D
  17. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    i've got a heavy ass diesel in the k5, and w/ 35's and no sway bar for the past year, i cant even tell its not there. it helps out a ton off road, and feels like a space ship on road around fast/hard corners.. feels cool.. just take it off, u'll love it
