wich x-fer case do I have
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Dec 2, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    Hey, my trasfer case does not function properly and I either need to adjust it fix it or buy a new one, Well I have a 79 jimmy automatic Who can tell me what transfer case I have???
    1979 Jimmy 4" skyjacker, add-a-leaf, 35" M/T's, Body Lift purchased.
    2001 Pathfinder LE Mile Marker Winch
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    New Process 203 transfer case, chain driven, cast iron, full time 4-wheel drive, with 2.01:1 low range. What seems to be wrong with it?
  3. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    it could be a 203 or 205 but i am preatty sur that it is a 203, is it full time 4 wheel drive? if it is then it is a np203
    hola
  4. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    79 was the last year that they used a NP203 (aka boat anchor). They went to a NP205 in 1980 with a slip output. What shift patter is on the knob?
    <P ID="edit"><FONT class="small">Edited by Wheels on 12/02/01 09:39 PM.</FONT></P>
  5. madups311
    Nov 14, 2001
    72
    VA
    Well the 4WD only engages if I push the shifter as far forward as possible and keep full pressure on it otherwise it won't stay in 4WD, that's what makes me think that there is a problem in the linkage
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    If it wasn't for the 203 we couldn't build doublers...plus they are actually quite strong. Their one big drawback is weight.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  7. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I dunno, if this will help, but have at it!
    "I ain't nobody, dork."
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  8. Wheels
    Aug 18, 2000
    638
    More than likely the holes are worn out where the linkage fits into, or the nuts on the levers coming out of the t-case are loose. You can adjust the linkage. Chiltons manual has a pretty good breakdown on this. And yes the range box on the 203 is the only good part on it. Don't get me wrong, the 203 is a little under rated but if you ever have the chain let loose on one, it's a long walk home, been there, done that, bought the t-shirt.
  9. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    my buddy that has a 78 jimmy that did the same thing...let me tell you how fun it was to be the passenger in the mud and have to hold on with two hands and keep your foot on the t-case shifter so itll stay in 4wd...fixed it just by adjusting the linkage...his only started after the body lift...
    Later
    Have you driven OVER a Ford lately?
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    After 1980, no K5 I know of would have a slip yoke 205. More than likely, they'd use the 208 or 241 in later years, instead.
    Only thing I've seen a slip yoke 205 come from was 3/4 ton 4wd '80s trucks with manual trannies or TH 400s. I have only seen a few K30s in my whole life, but I'd assume that they had them too after '80.
    Tim
  11. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    dont talk smack about the np203 its a great case. a chain is a normal wear item and most of them last 250K+ miles even under extreme abuse. Nobody ever thinks to maintain the t-case. maybe add oil once in a while and thats it. So you get what you had comin' if the chain breaks. would you take a 250K mile motor out on hard offroading trips? not without a new timing chain i hope &lt;/rant&gt;
    Ill take a np203 over a 205 slipyoke ANYday
    mike
  12. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    hey
    good link
    i think i have seen that somewhere before
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Man your album is getting a lot of miles on it Michael![​IMG] You should get a royalty or something...
    Rene
