Wide or skinny tire??
Discussion in 'The Garage' started by 85mudblazin, Aug 31, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Which one is the best, I do rocks and muddy trails, I thought skinny for more pressure in one spot for better traction but the wider tire would have better stability, What yall think??
    -Chris
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Wide.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i always sorta liked wide rears and smaller fronts /forums/images/graemlins/thinking.gif
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    wider for mud for better floating so you keep on top of the mud, not in the mud.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    daaayum, I am THE search master /forums/images/graemlins/pimp1.gif
    previious thread
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    skinny for rocks, wide for mud. I gues you will have to decide. I have always liked 14.5" wide tires
    Dan
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I like my skinny tires. As long as you are not in any bottomless mud pits they work fine.
  8. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i THINK MINE ARE 13.5 AND THEY ARE GREAT,IN THE MUD BUT NOT REAL FAT.
  9. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i've always thought wider was better, i'd take a 16 inch or wider tire if i could fit one, what are the draw backs of 15-18 inch wide tires?
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    the drawbacks are fender clearence /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Wider is better.
    Having had both, I can see advantages to both, but I'll never go back to anything narrower than 15".
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Wider is usually better. As stated in mud you want to float on top of the mud. Wide tires have a larger contact patch to keep you on top of the mud rather than stuck in it. For rock crawling wider is better as well. Watch a crawling video sometime. Those guys run wide tires and air them way down. Then as they go over the rocks the tire trys to wrap itself around the rock like a hand providing better traction and again a bigger contact patch.
    Skinny tires are best for daily driving in bad weather. In heavy rain the small contact patch of the skinny tire had less water to move out of the way to contact the road so less chance of hydroplaning. In winter and light to moderate snow skinny tires are superior. The object in this situation is to dig down through the snow with your tires until you hit pavement. If the snow is deeper than 12" floating on it is really your only option so a wide tire aired down is preferrable there.
    Basically it seems for any off roading wider is indeed better.
  13. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I had 38/11 boggers and now have 38/15 TSL's and like the TSL's a lot better!!!
