Widened 8 bolt Hummer Wheels---Lower Price---
Discussion in 'Tires | Wheels' started by Blazr77400, May 23, 2006.
  1. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    I am selling four(4) 11.25" wide by 16.5 diamter 8 bolt hummer wheels. They have the stock 7" backspacing with the stock 8 bolt pattern. I have widened them from 8.25" to 11.25". I added to the outside of the mounting flange. All the bolts are there. The O-rings are in okay shape. $400 I will ship, but buyer pays.
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    How does the beadlock work on 8 bolt wheels I'm looking for 12 bolt wheels so I can use PVC locks But I'd consder 8 bolts if there comparable your price is about what I'm wanting to pay
  3. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    The wheels work the same so you can use some PVC inserts. The difference between the 12 bolt and 8 bolts is the mounting surface on the 12 bolt is on the outside piece and the 8 bolt is on the inside piece. The 12 bolts are also a little thicker(iirc).
  4. yellowK20
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    Okay, do you have the PVC inserts??? and what would shipping be to 88310 I'm also looking at some 12 bolt H-1's But he's not sure how many he has I'll gaet back to you on these they may work did you have them on a Dually front???? does the extra width affect inboard Clearance????
  5. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I dont have any of the PVC inserts.
    Not sure on the shipping.
    I had them on a set of 404 mogs that are 74.5" wide.
  6. yellowK20
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    Okay, did you use the runflats???
  7. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    When they were the stock width i did.
  8. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    The cheapest I can find shipping is a $150. Each wheel weighs 40lbs and the will need a 18x18x11 box.
  9. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    why did you widen them? i thought running h1s on 42/15's would be fine:confused:
  10. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    They were okay, but they started wearing the centers of them out. I was running 15psi in them and they were still wearing. I also thought the truck was a little narrow.
