wider 14-bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefheaphy, Apr 10, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Is there such thing as a wider 14ff that matches up with the DRW front 60 and if so what can it be found on?
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    3/4 ton or 1 ton dually, I believe...
  3. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    I just found a 60front and Dually rear in N. Billerica. The rear is real narrow. The way the rims are make it look wide.
    Need any parts BigBlaze? I have a blow 10 bolt rear and good 10 bolt front. 4 inch front springs, 4 inch blocks. TH700. Np208. close to junk 33's on good alum. 6 bolt rims.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    G30 van rear will match an srw 60
  5. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    I have a DRW 60 front
    Is the rear of the G30 van wider than 1 ton SRW pickups?
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    iirc, yes..
  7. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    junk yard hunt
    I love junk yard hunts. Looks like I know what im doin sat.
    G30/1 ton chevy van from around 77-91 or so I assume?
    I'm pullin a np208 and th700 and my 10 bolts in a couple weekends if you need any partz.
  8. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    yo, what is IIRC?
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    it means if i remember correctly
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Dually rear 14bff is wider than VAN G30 14bff which is wider than SRW 14bff which is wider than Cab and chassis 14bff :D
    What you saw as narrow from a dually is probably the Cab and chassis 14bff.
    Is it 58" from WMS to WMS (wheel mounting surface)
