width and diameter of 79 k10 U bolts ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 18, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    anyone know the width and diameter of 79 K10 U bolts, front and rear ?
    and where;s a good place to get front ones around 11" long overall and rear ones around 14" long overall ?
    thanks for anything
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I don't have the measurements, but an automotive parts supply store should have both the measurements and the u-bolts.
    11" long sounds mighty long for the front. I sure hope you have a thick spring pack and sure as hell aren't putting blocks up front.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    On the front axle, the 3 u-bolts are a 3" i.d. and the 1 larger u-bolt is a 3 5/8" i.d.
    All 4 are a 5/8" rod size.
    Rears are also 4 u-bolts all with 3" i.d. and 5/8" rod size.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    adding leaves, unless front packs are cheap yet ?
    front bolts oddball sizes hmm, i hope small napa store has u bolts liek this or im toast, we dont have any thing else around here in farmer land.
    what i did was add 4" to length of current springs, but i only measure outer-most ones on driver side, so..
    thanks
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thanks for posting info, i appreciate it /forums/images/icons/laugh.gif
