Wierd Dome light question???????
Discussion in '1983-2005 S-Series models' started by Ck1500, Mar 9, 2002.
  1. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    anyone ran into this???? the DOME LIGHTS WON'T Go off and i made sure the switch was off, and the doors are all closed?? i am going to look at it a little closer tommarow, and hopefully i'll figuire something out.
    thanks
    Ck1500
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Back hatch closing all the way?
    Every once in a very great while, my hatch closes crooked, or something, and the dome lights don't go off. If I open the hatch and close it again, it always shuts them off.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    A fuse is blown. Check the 20A ones. Cant remember which one, but I'm pretty sure its blown. I know it sounds wierd, but i think i'm right...
    John
  4. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    My dome light never works, except when i hit the horn, then the horn doesn't work. It looked like the previous owner did some custom wiring. People have told me i may have a bad ground.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have a '91, right? If so, then check the fuse for the cigarette lighter. My wife had a cell phone with a messed up lighter plug, that caused that fuse to blow frequently. When the lighter fuse was blown, the horn and dome lights would behave exactly as you describe. /forums/images/icons/shocked.gif
  6. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Thanks, that was the problem. That dome light problem has bugged me since i bought the truck a year ago. Go figure it was the circuit i never checked.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Automotive wiring is some strange stuff.... /forums/images/icons/shocked.gif Glad that fixed it! /forums/images/icons/cool.gif
