wierd question.
Discussion in 'The Garage' started by MTBLAZER89, Apr 24, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hi all here is th question. My buddy is doing a solid axle swap on a 94 Nissan. He has a Dana 44 from a widetrack Cheerokee. He asked me if my 10b would be a suitable rear axle to replace to match the width, and how it will hold up under a Nissan with 35's. Thanks
    -Brian
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    If he is running a stock Nissan 4 or 6 banger I would think it would hold up better than in a heavy K5 w/ a small block...but then again, it is still 35's on a 10bolt.
    Probalby depends on what he does w/ it?
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Nissan's are lite it should hold up fairly well I'd think It could work long enough to get something better /forums/images/graemlins/truck.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think it would be fine If he could find a 12bolt that would probably be slightly stronger
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I think it would be ok, also. My friend has a XJ and the hot axle swap is front&rear D44's. The 10 or 12 bolt isn't really that much different strength-wise from the 44 so I think it would work.
  6. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I think your freind will be ok due to who much it weighs
    A frend in the club has a 10 bolt under a 4runner with 38
    inch swampers and is hardcore and has no trouble.
  7. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Don't know if he would want to put the money into it, but a full float kit in a ten bolt makes a decent axle for light 4x4's. You get the clearance and low weight without the c-clips.
