wierd rubbing noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wraenking, Feb 23, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok guys, just recently i am hearing a loud sort of rubbing sound coming from what appears to be my left front tire area. its all stock, no lift or whatever.
    seal of some sort maybe?
    thanks
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Rubbing all the time, or only when you turn, back up or what?
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    seems to be mostly when turning.
  4. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I have that similar type of thing on my 94 2wd P/U, i found out yesterday what it was, it was the flaps that are installed on the fender wells that help keep water out of the engine compartment, splash guards, one of mine is ripped and sticking out just a bit, so when i turn the wheel to the right while backing, the tire rubs on it. Check out those splask guards, if thats not the case, turn the wheels all the way and see if you can't see anything that "might" rub.
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    nothing hanging, or rubbing when i turn the tires. now, i did notice thaqt there is some kind of steering arm only on the drivers side? im new at gearing, so im not sure what its called. possible maybe that that is going bad?
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Do you have larger than stock tires or a suspension/body lift?
  7. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    nothing of the sort. all stock
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well with out actually being there to play with it, you are going to have to try to recreate the situation with someone outside the vehicle and listening for the sound, going to have to pin point where it is coming from. If something is rubbing in the wheel wells, there should be some sort of rubbed material somewhere, either cleaned, chewed up from the tires. What size tires are you running?
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    31 's. i called my bud, he said hell listen for it this weekend when we adjust the timing so i can try to pass emissions
    thanks alot
