Wierd Vibration from k10--detailed
Discussion in 'The Garage' started by WRENCH-HEAD, Mar 23, 2006.
  1. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I have this wierd vibration from the truck that I can't figure out. The truck idles smooth with no misses, however as I rev the motor from around 1500 to 2000 rpm the engine shakes bad enough to make the entire truck rattle. It revs up smooth so I don't think it is a timing problem it feels like a really bad loss of balance on something. It does it when driving/park/neutral at all temps. I have electric fans and the motor is a crate 350 with 5000 miles on it. The water pump is new, but the alternator and the power steering pump are about 2 yrs old. I also installed a new torque converter at the motor install to eliminate the stall converter from the previous build. The vibe just started one day out of the blue. I went into a hardware store and it rode fine the way there but when I started it and drove through the parking lot it began and has remained. My next test is going to be to remove the belts to eliminate the accessories and next unbolt the trans and torque converter to eliminate those. Could a vacuum leak cause this without affecting idle quality. Oh and it is TBI injected. I put 5000 miles on it and it ran awesome now this. :dunno:
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Any fault codes?
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    When you put the crate in, did you replace the harmonic balancer with a new one or reuse the old one?
  4. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Never mind; I assumed it was a GM TBI setup (it isn't). Have you got a laptop to hook up to the Holley controller, or is that not a feature of their TBI systems? Which Holley TBI system is it, specifically?
  5. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    It is the Holley 950-21s and I have already monitored all of the vitals and all is well as far as the laptop is concerned. Yes it is a new balancer as well.
  6. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    have you gone through and rechecked all of the mounts?
  7. WRENCH-HEAD
    Dec 25, 2005
    327
    Littleton, CO
    Yep, they are the ORD heavy duty mounts and a urethane t-case mount and all is well.
  8. 87350blaz
    Oct 23, 2005
    33
    New Mexico
    what about the bolts that hold them on? did they come lose?
  9. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    broken flexplate?
  10. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Everytime I have seen a broken flexplate it made a ticking sound...almost like a bad lifter
  11. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    I had a harmonic balancer that slipped on the rubber which holds the balancer together. Caused the same symtoms your experiencing.
