Will 1/2 or 3/4 ton front springs fit on a 1 ton?
Discussion in 'The Garage' started by jkce457, Apr 2, 2005.
  1. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    I think they're the same, but just wanted to confirm. I'm very limited in spring selection with a 1 ton rating, and the springs are much stiffer of course. I'll trade the load capacity for more flex if they will fit. I'm planning on 4" TC HD's if they will fit, and a 4" shackle flip in the rear. I'll probably remove atleast the overloads in the rear to help with flex.
  2. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    Come one....there must be SOME 1 tons out there. Anyone?
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Yep, they'll fit. I have a set of 3/4 ton lifted springs onm my 82 K3500.
    Eric M.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    IIRC a 1 ton front spring is 3" wide whereas a 1/2-3/4 ton is only 2 1/2" wide. I would think that you would need to use a spacer of some sort in the spring hanger bracket to make up this difference otherwise the spring will move around 1/2" side to side in the frame brackets. :dunno:
  5. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    I've got three 1 tons, they all have 2 1/2" wide front springs.
    Eric M.
  6. jkce457
    Nov 22, 2002
    135
    Southbury, CT
    Okay, thanks for the response guys. I looked on Sky Jacker's site and they show the same part# for 1/2, 3/4, and 1ton front springs, so it looks like anything will fit.
