Will 14 bolt FF disc brake brakets work on an Eaton axle?
Discussion in 'The Garage' started by 1-8-4-3-6-5-7-2, Sep 11, 2006.
  1. 1-8-4-3-6-5-7-2
    1-8-4-3-6-5-7-2 Registered Member
    Jun 16, 2006
    58
    In the Garage
    Hey all,
    I have an Eaton axle in the rear of my '72 C20 Suburban and was wondering if the 14 bolt FF disc brake brackets (like the ones Kert makes) would fit my older Eaton axle? Would it be a bolt-on affair? And use front rotors from a K20? I'm not sure if I have an HO52 or an HO72.
    :laugh:
  2. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    I think they will work,I have an eaton rear in my yard truck because I got it for a hundred bucks with 5:13 gears and a Detriot.The brakes were junk so I put everything from the backing plates out including the bearing hubs from a M1008 14bolt rear on it.I had to put a 1/2" spacer between the backing plate and 4bolt axle flange to make it spaced right.
    Long story short is the 4bolt eaton flange matches the 14bolt flange pattern and should work but you may have to adjust the spacer thickness accordingly!
  3. sweetk30
    Nov 1, 2004
    25,537
    534
    horseheads , ny 14845
    yep thay should. my friend did it. and 90 % of the drum stuff is the same as the 14 ff axle
  4. 1-8-4-3-6-5-7-2
    Jun 16, 2006
    58
    In the Garage
    Cool, thanks guys! ;)
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I as well can concur that they are the same brackets and use the same rotors for the eaton. My friend did this to his eaton axle in his 69 2wd a few years ago.
  6. 1-8-4-3-6-5-7-2
    Jun 16, 2006
    58
    In the Garage
    Thanks. It's good to know that it's a direct swap... I really hate drum brakes, and from what I've read replacement drums are impossible to find
