will 15'' wheels fit dana 44 8 lug front axle?
Discussion in 'The Garage' started by MJB774X, Oct 27, 2002.
  1. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    will 15\'\' wheels fit dana 44 8 lug front axle?
    I have a 14 bolt, now I need to convert the front to 8 lug, I need to know if I'm going to have to put new wheels and tires (16.5") into my budget? /forums/images/graemlins/k5.gif
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    Re: will 15\'\' wheels fit dana 44 8 lug front axle?
    8 lug 15's will fit the front...but you will need to grind the calpiers and backing plates. How much you need to grind depends on the backspace. I have 15x10 8 lug rims with 3 5/8" backspace on my 8 lug D44...
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. They're a tight fit, but it can be done. I just installed a set of 15x10 chrome wagon wheels on mine. /forums/images/graemlins/cool.gif My wheels came with a 4.25 inch backsapcing, so I had to grind quite a bit on the backing plates, right around the tabs that locate the caliper. I had to take off enough that I ended up backfilling the inner side of the tab with the welder to keep it solid. /forums/images/graemlins/shocked.gif With less backspacing, you wouldn't have to grind so much, but the tires will stick out of the fenderwells further.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, my front axle is a '74 Dana 44 HD, which is the first design. I'm not sure if the grinding would be more or less on a 2nd design 44. /forums/images/graemlins/blush.gif
  5. MJB774X
    Sep 26, 2002
    574
    SO CAL
    Does anyone know aprox. about how much material needs to be machined off the caliper? does taking material off affect the strength of the caliper enough to where i need to worry about it? thank you to everybodys advice, its much appreciated /forums/images/graemlins/smile.gif
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I just did mine the other day. I swapped the D44 stuff onto my 10 bolt for now till I get matching gears for the rear to put the 44 in. (the D44 has 4.88s, need to get 4.88s for the 14 now) I have pics in my Webshots of how much I ground. I have a before shot still on the 6 lug stuff and an after shot w/ the 8 lug. Same calipers.
    I ground them, painted them flat black (flat black dries REAL fast) and hung the wheel w/ 2 lug nuts. I then spun the wheel and I could hear scraping. I would them remove the wheel and see where I hit. I dont know what my back spacing is but, I have 14 wides and they hang WAY out there.
    When all was said and done you could slide a credit card in there. Its not much, but they dont rub. If you care to look they are in the "RE-construction" album.
    It was more like taking off the roughness of the casting and any high spots of the caliper and then a bit more in my case.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Not much has to be taken off the caliper, but it is made of some hard stuff so it takes a long time to grind it down. /forums/images/graemlins/shocked.gif My backing plates were in the way more than the calipers were. I'd guesstimate that I only took maybe 1/8 of an inch off of the calipers.
  8. MJB774X
    Sep 26, 2002
    574
    SO CAL
    did you grind the backing plates or torch them?
  9. MJB774X
    Sep 26, 2002
    574
    SO CAL
    are the hubs the same?
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I ground the backing plates. What do you mean be "are the hubs the same"? I didn't do anything with the hubs. This truck had 16.5x9.75 wheels on it for the last 15 years or so. I just changed over to the 15x10's for the bead retention. /forums/images/graemlins/cool.gif
  11. MJB774X
    Sep 26, 2002
    574
    SO CAL
    I thought you converted yours to 8 lug, I wanted to know if my warn hubs from the 6 lug stuff would work on the 8 lug stuff? that should be easy to find out though, thanks for the info /forums/images/graemlins/grin.gif
  12. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    As long as they are the same style, ie internal. 1/2 and 3/4 ton axles are really not much different.
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, as long as the parts are from the same era, the hubs will interchange. /forums/images/graemlins/cool.gif The external style have six 3/8's inch bolts that hold them onto the wheel hub, but I don't think those were ever used on the 1/2-ton axles. The internal style have 6 small allen screws that hold them onto the wheel hub. Those will interchange between the 1/2-ton and 3/4-ton internal style axles, even if one is a Dana 44 and the other is a 10-bolt. /forums/images/graemlins/cool.gif
