WILL 15" WHEELS FIT OVER 14B SEMI-FLOATER DRUMS?
Discussion in 'The Garage' started by MJB774X, Sep 26, 2002.
  1. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    WILL 15\" WHEELS FIT OVER 14B SEMI-FLOATER DRUMS?
    I KEEP BREAKING 12BOLT RING AND PINIONS. I WANT SWAP TO A14 BOLT, I KNOW MY 15" WHEELS WILL NOT FIT ONTO A FULL FLOATER BUT I WAS THINKING MAYBE A SEMI FLOATER. DOES ANYONE KNOW IF 15" WHEELS WILL FIT OVER 14B S-F DRUMS? DO THEY MAKE 6LUG AXLES/DRUMS FOR A 14B S-F? I WOULD LIKE TO AVOID CONVERTING MY FRON TO 8LUG. I JUST BOUGHT NEW TIRES AND I DON'T WANT TO HAVE TO BUY 16.5'S.ANY SUGGESTIONS? /forums/images/icons/confused.gif <font color="red"> </font color> <font color="red"> </font color>
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    Re: WILL 15\" WHEELS FIT OVER 14B SEMI-FLOATER DRUMS?
    15 inch rims will fit over the rear drums on a 14 bff just not clear the front calipers when switched to 8 lug because of the larger backing plate and rotor.if you can find a semi float that is 6 lug it will work.i think they came on some suburbans in the 80's
  3. MJB774X
    Sep 26, 2002
    574
    SO CAL
    I'VE BEEN TOLD 15" WHEELS WILL NOT FIT OVER FULL FLOATER DRUMS ANYBODY ELSE HAVE SOMETHING TO SAY?
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    YEH SOMEBODY TOLD YOU WRONG /forums/images/icons/shocked.gif
  5. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    15" wheels will fit on either the SF or the FF axle. Just dont go hog wild with something like 6" back spacing. The 14SF was available in 3/4 ton 'burbs and trucks beginning in 82 or 83 (or somewhere near there) and were 8 lug. They were not available in 6 lug until 88-89 when used on "heavy" 1/2 ton or on light duty 3/4 tons. If you get a factory 6 lug SF axle you will need to move the spring perches. I used an axle from an 85 3/4 ton 'burb and swapped the 6 lug shafts into it and converted to rear disc.
    hope this helps....
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> IT WILL WORK JUST FINE.
    Try pushing this button, please.
    [​IMG] </font color>
  7. MJB774X
    Sep 26, 2002
    574
    SO CAL
    DISC WOULD BE GREAT, IF I WENT THAT ROUTE DOES ANYONE KNOW IF THESE DISC ARE A BONEYARD ITEM OR ARE THEY AFTERMARKET CONVERSION KIT?
  8. beater74
    May 29, 2001
    1,749
    atlanta
  9. Scooter
    Nov 18, 2000
    551
    Grandview, Mo.
    I used the bracket from TSM and sourced the rest of the stuff from my local O'Reilly Auto Parts. Personally, I would only use junkyard brake parts (i.e. calipers) as cores. To me, brakes are too important to a half-assed, cobbled together job on.
  10. burrito
    burrito Newbie
    Sep 22, 2002
    3
    Yes, 15's will fit on a 14bsf. Installed one on my 91'. Need to relocate spring perches. I found one under a 95 3/4ton with six lugs. Good Luck
  11. MJB774X
    Sep 26, 2002
    574
    SO CAL
    Does anyone know if all newer 14bsf 6lug axles will go into older 14bsf housings (closer spring perches)? are drums the same diameter? are backing plates the same?
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    To clarify...will 15"aluminum wheels fit on the 14 bolt SF, or only steel? Thanks.
  13. burrito
    burrito Newbie
    Sep 22, 2002
    3
    Not sure if the axles are the same between older and newer 14bsf, and I see no reason why GM would change. I'm running 15x10 alum. rims on my newer 14bsf.
    Joe in Phoenix
    90 Blazer, D44 front, locked 14bsf w/456 grs.
    35" BFG Mudders
