will 1971 dana 44 3/4 ton knuckles work on a 79 dana 44 K10 axle ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 27, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    will the bolt on and work ? or is there a difference after early /mid 70;s somewhere
    flat tops are what ?
    thanks
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im pretty sure the knuckles are all the same, its the spindles and hubs that are different.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the spindle as in the actual spindle shaft that the rotor bearings ride on, right ?
    thanks
  4. outlaw612
    Feb 11, 2001
    2,342
    thats the one!
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    awewsome, so then means all balljoints 4x4 71-up are same,
    ill try and learn the flat top thing later unless someone knows
    right now what that means,.
    thanks!
  6. outlaw612
    Feb 11, 2001
    2,342
    Let me see if I can find a pic of the flattop knuckles. Basically they are just what theyre called, theyre knuckles with flat tops. /forums/images/icons/blush.gif
  7. outlaw612
    Feb 11, 2001
    2,342
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yet they wiol work on any dana 44 housing right ? different balljoints, or ? how does flat top give any clearance for offroaders ? being that they are flat does that mean they arent as tall ofg a knuckle as ones that are not flat topped ?
    thanks
  9. outlaw612
    Feb 11, 2001
    2,342
    I think the balljoints would all be the same. As far as the flattop knuckles, they are needed to use crossover steering. The steering arms locate on top of the knuckle like the stock arm, but theyre a different design. I dont know the specifics though.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    interesting
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    The thing to watch out for with swapping the knuckles is the tie-rod position where it bolts to the knuckle holes.
    The older ('76 and older) have tie rods mounting on the top part of the knuckle and the tie rod therefore "bends" down a little bit to clear the front springs.
    The newer ('77 on up) have tie rods mounting on the bottom side of the knuckles.
    If you took the knuckles off and laid them side by side, you will see where the casting is different a different height than the other knuckle.
    The general rule to use when swapping the knuckles is to use the same year tie rod as the knuckle being swapped in. /forums/images/icons/wink.gif
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ouch, i was wondering where the catch was hidden at, hehe
    thanks
