Will 305 heads bolt onto a 350?
Discussion in 'The Garage' started by deek, Apr 15, 2004.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I got a set of Rebuilt heads for $$free$$ /forums/images/graemlins/thumb.gif, but i was told that they might be for a 305? would there be any difference between the 305 & 350? If so what should i look for? & once again are they interchangeble?
  2. rnss82
    rnss82 Registered Member
    Mar 28, 2004
    22
    oregon,wa.
    im not to sure but i think they will bolt right on but make suure the combstion chahmber cc isnt to same
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Yes they will. Most 350's have a 76cc head as where the 305 has a 58cc head.
  4. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    [comic book guy] Worst Heads EVER! [/comic book guy]
  5. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    sorry to hijack but why would you want to put smaller heads on? Does it increase the compression?
    lmk
    Nick
  6. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    THERE FREE! /forums/images/graemlins/deal.gif
    & im in the proces of rebuilding, but is on a buget. so i figure I can do the bottom end now, & run the new rebuilt (complete) heads, then when I recive the funds I can go with larger heads, ...can we say vortecs
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    They don't flow as well but compression will be pretty high so that may make up for it.
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Post the casting #'s and someone can probably give you an answer on what you have. /forums/images/graemlins/thumb.gif
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the compression will make more power, but the newly found restrictions that some 305 guys try to pass off as ports and valves will kill any chance of making the power known when you get on the loud pedal.
  10. parker
    parker Registered Member
    Apr 14, 2004
    40
    az,
    yes they will be just fine 58 cc combustion so good gas only retard your timing and enjoy alittle extra horse power
  11. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Yep, they will for sure bolt on. Bump your compression a little and as somebody said they won't flow as well but they make better low end torque. great for a truck.
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, truck heads and 305 HO had 1.84/1.50 valves and 58cc chambers.
    Post up the casting numbers or look them up yourself to find out what they are for sure.
    305 heads are a poor head solution as far as performance goes. However, it's hard to beat free.
