will 31-10.50 BFG AT's fit on a stock 92 S-10 4wd?
Discussion in '1983-2005 S-Series models' started by PGL4VT, Nov 11, 2002.
  1. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    will 31-10.50 BFG AT\'s fit on a stock 92 S-10 4wd?
    see subject for my question.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: will 31-10.50 BFG AT\'s fit on a stock 92 S-10 4wd?
    Nope. I've got a '91 and 30x9.50's is all I could stuff under it. Even then they'll slightly rub the rear of the front wheelwells at full stuff unless you crank up the torsion bars and raise the rear to match. /forums/images/graemlins/frown.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I heard even with cutout flares you can only go up to 31's.
    My wifes 91 is gettin 31's(and flares). I wanted to go 33's.
  4. davester8022
    davester8022 Registered Member
    Dec 5, 2002
    5
    Stationed in Missouri but hail from Idaho
    I have a '91 sonoma with torsion bars cranked and add-a-leaf in the back with 30x9.50's on it and they are a tight fit.
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Nope....we put that size on a '91 with a 3" body lift and they fit fine...but wouldnt fit stock....
  6. s10350power
    s10350power Registered Member
    Aug 6, 2002
    16
    Maryland
    I hvae an 88 s-10 blazer with a three inch body lift and i fit 30's tight but i dont rub. My friend had a same body style s-10 with 6" lift and he fit 33's with cut outs witch sucks lol
  7. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    I've got a 92 S10 4x4 with 31x10.50 on it and they do rub on the rear of the wheel well in the front, they fit well on the back though (not much suspension travel though), oh ya that's with the torsion bars cranked and add a leaf(s) on the rear, I'm thinking of going with 30x9.50
  8. Blazen89
    Blazen89 Newbie
    Feb 14, 2003
    My 89 blazer has 32's with 3" body lift and trimmed fenders still occasionally rubs
  9. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    I did it NO PROBLEM! Check out my article on how I trimmed my fenders. The 31x10.5x15s that I am running have only rubbed on the front a VERY FEW times and that was minimal... But my shocks were SHOT, too. They've never rubbed on the back. I am very pleased and wouldn't think twice about doing it again. The article can be found under "Technical Articles" on my website listed in my sig.
  10. steves89s10
    steves89s10 Newbie
    Nov 8, 2002
    I run 33x12.50's on my 89 S10.
    3in Body Lift
    T-Bars Tweeked/Shackles
    A Little Triming /forums/images/graemlins/thumb.gif
  11. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    just put a set of 31-10.50's on my wifes STOCK 91 S-10. tell me they don't fit!! just got to use a big hammer!!
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Not all of us have had the fenders removed courtesy of the road salt crews. /forums/images/graemlins/wink.gif
  13. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    < got 30x9.5x15s on a stock 99 s-blazer 4 door 4x2 they rub at full lock in reverse only... go figure they fit
  14. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I've got 30's on my '91, but 31's won't fit it without hitting. At least true 31's... /forums/images/graemlins/wink.gif Some tires are marked 31 on the sidewall, but can actually be as small as 30.2 inches tall. /forums/images/graemlins/shocked.gif
  15. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    well, you called that right!! wasn't much to hammer over. still rub the rocker rails in the front now and then
