will 33's fit on my stock K-5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JasonMan, Apr 10, 2000.
  1. JasonMan
    JasonMan Registered Member
    Apr 6, 2000
    5
    North Carolina, U.S.A.
    will 33\'s fit on my stock K-5?
    I've got a 1980 K-5. I've had it for about a year now and have been gradually doing stuff to it to fix it up. now that i finally got the money to put some tires on there i'm wondering if 33*12.50's will fit without rubing. I've got 15*8 centerline wheels with 31's on there now and they look like go-cart tires. i'm just wondering weither to put 32's or 33's? i've heard from a couple of different people that 33's might rub in the front. Anybody got any suggestions.
  2. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    Re: will 33\'s fit on my stock K-5?
    I've got an '89, all stock. 33's have never rubbed yet, and i've been in the dirt a time or two. nothing too crazy, but they definitely fit ok.
    <font color=purple>delta9blazer</font color=purple>
  3. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    How are your ball joints holding up?
    i would like to go 33's
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>If your springs are still good and not sagging, you can fit them and they'll only rub when it's twisted up off road, even then it will be minor. if your springs are bad, then they'll rub the back of the front inner-fenders when you turn, but trimming can fix that</font color=blue>
  5. Kennedy
    Kennedy Registered Member
    Mar 1, 2000
    90
    Los Angeles, CA
    I also have an 89 with 33" BFG Mud terains and no lift. The tires were bought new and mounted on the stock 15x8" aluminum wheels. Funny enough they only rub when I make turns into parking spaces. They never seem to hit the body when I am off-road. I guess I am not trying hard enough:)
    David 1989K5
  6. Udy
    Udy Registered Member
    Apr 2, 2000
    79
    fairport NY
    I have a '91 that had 33x12.5 BFG ATs on the stock 7 inch wheel. The only rubbing I had was on the drivers side steering geometry (minimal though) when turning hard right.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you mainly just drive it on the road, and don't mind some occasional rubbing, then go for the 33's. You will also probably notice what seems like a decrease in power with the larger tires. If you want to go off-roading in the twisty stuff you will need either a lift or major fender trimming. I have a 4" lift and had to trim the fenders slightly to clear 33's, but the swaybar was unhooked and it was during some pretty tough trails.
  8. 83DK5
    83DK5 Registered Member
    Mar 13, 2000
    19
    Kansas North East
    I have an 83 with stock rims and 33's I have no problems with rubbing. I did some minor trimming just in case though. Also I have the from the factory quad shocks on the front.
    Blazers Rule especially Diesels
