will 35x12.50 fit under a 86 shortbed with 4" lift
Discussion in 'The Garage' started by Tshane, Mar 26, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    will 35x12.50 fit under a 86 shortbed with 4\" lift
    I have heard that 35x12.5 will fit under a 86 chevy with just an 4" lift. I dont need major flex but i dont want the tires to hit everytime that the truck does flex. I'm willing to do minor fender trimming. Tell me what you guys think. I'm wanting to stay away from a 6" lift because of all the extra money in putting new driveshaft.
    /forums/images/graemlins/truck.gif
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    Re: will 35x12.50 fit under a 86 shortbed with 4\" lift
    yes...they will fit. they will prolly rub though when u r fully flexed.
    NITRO
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    They will fit as long as the tires are mounted on 8" wide rims.
    I ran 4" lift and 35's on 8" wide rims and never had any rubbing at all.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I have "HEARD" they rub pretty bad with 10 or 12 wides when you go wheelen but not to bad on the street. Personally I would go 6in for 35's but then agin you said you dont mind triming
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I have an 86 K10 shortbed, and I ran 35's with a 4" Rough country lift and it didnt rub. At that time i never did anything but mud. If youre willing to trim youll be fine.
  6. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I am running 38.5 with 4" of lift /forums/images/graemlins/thumb.gif
  7. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I'm running a 4' rough country with 35x12.50 on 15x10s.
    Without the swaybar I had to trim the rear of the front fenders slightly. If I could figure out how the post a pic into a post, I could show you.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    why not do a 6in lift?
  9. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My wheeling buddy has an 86 shortbed w/ a 4" Rancho lift and 35's. He only hits the rear of the front fender once in a while as others have said. He wishes he had a 6" lift though. Which is why I am doing a 6" lift on my 74 Blazer and will probably go with 35's as well.
  10. audacious
    audacious Registered Member
    Mar 10, 2003
    34
    tx, austin
    i am looking to do the same to my 86 blazer next week. i am going with 4" tuff country setup on the frount. and a shackle flip from echobit on the rear (so i can always go to a 6" if needed without alot of problems.) i have read every post i can find and they say 35's will be no prob. never saw that i needed to change the driveshaft thought for the 6" lift. just the usual with brake lines and stearing arms. mabye a plate to beef up the steering houseing. thats my $.02 /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  11. mudtruck
    mudtruck Registered Member
    Apr 2, 2003
    14
    pa
    I'm running a 4 inch lift and 39.5's /forums/images/graemlins/thumb.gif
