Will 35x12.50x15 tires fit with 3'' body lift,4''suspen. lift w/o trimming?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, May 15, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    Will 35x12.50x15 tires fit with 3\'\' body lift,4\'\'suspen. lift w/o trimming?
    Ok guys it's time to spend some dough for some meats. I was wondering with a 3" body lift 4"suspen. lift will 35x12.50x15 tires fit on Bamm Bamm without trimming my new fenders i just bolted on or do I have to settle for 33x11.50x15 tires instead? Thanks alot.
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Re: Will 35x12.50x15 tires fit with 3\'\' body lift,4\'\'suspen. lift w/o trimming?
    What year is it and what wheel are you useing
  3. Chrome Moly
    59
    88' k5 with US Wheels steel 8 spoke 15x10
    Chrome Moly
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I think it depends on how extreme you plan to get off road. I've had 33's on a stock chevy pick up with no problem but I wasn't doing alot of off roading either. The tire dealer should be able to tell you yes or no for sure. If he doesnt have the answer I'd look elsewhere for tires
  5. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    The 35's almost look small with the 7" of lift. I have the same thing on my '77 and I think that I could fit 38's with very little trimming. The tyres are 35x14.5x15 inch Ground Hawgs on 15x10 8 lug rims. I'll try to get a picture of it posted but I don't think that it'll happen for a while.
    NEVER been stuck... *yet*
  6. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    FIT..EASY I'VE GOT AN 84 W/ONLY 4" OF LIFT AND RUN 35-12.50 MUDS AND NEVER HAVE HAD A PROBLEM EXCEPT FOR MY CHROME WHEEL TRIM AND IT GOT IKSCHNAYED SHORTLY AFTER. BUT TRUCKFAN
    IS RIGHT IT MIGHT LOOK A LITTLE FUNNY. MAYBE 36'S OR ONLY 1-2 IN BODY LIFT. GOOD LUCK
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
  7. blazer72
    Apr 13, 2000
    939
    KCMO
    Now see my 72 had 35s on the stock 8x15 wheel and they fit fine, even in extream off road. But the same will not fit 73 and up! without lift. after changeing to 10x15 wheels though I needed to do a bit of work on the front fender now just a hammer hit or so, it's just a bit of a rub bairly.
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Chrome Moly,
    It definately would fit. I run that exact set up, 4"susp, 3"body, and 35x12.20 tires. No trim. I have to agree with Truckfan2. The 35's look a bit small with that lift.
    Boss
  9. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Make sure the offset on your rims is the right one.Mine stick out too far and needed a body lift.Mine are 15.5" wide though too which probably has a lot to do with it too.
    <font color=red>Wanna'keep wheelin? Get involved!
    Check the "Land Use" section of this board.</font color=red>
  10. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Shouldn't have a problem. I have a 6" lift with 35's and it looks fine. A lot of my friends are running the exact same lift as you are, with the 4" suspension and 3" body and it looks fine. It's all just a matter of opinion and taste. Some like the looks of it and some don't. Personally I think it would look fine. I'd say go for it man! :)
    Alex
    Wichita, KS
    What me get stuck? NEVER!!(Famous last words)
  11. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have only rubbed my fenders when under some major twist. Check out the looks here if you like. Mine are 35x15.5-15 Swampers. Wider than yours, but same idea.'
    http://sites.netscape.net/mikesthmpr/thumper
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
