will 38x15.5x15 fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, May 3, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    I have an 84 K-5, with 4 inch susp lift and 35" Trailblazer M/T's. Within the next week or so Ill be puttin on a 3 inch body lift and 1 inch zero rate add a leaves all the way around. Giving me a total of 8" of lift. Will i be able to run 38x15.5x15 radial swampers? I dont flex very much. I just like to play in the mud. The only cutting i will do is just minimal stuff you wouldnt even be able to see when looking at it from the side. Thanks for any info you have on this.
  2. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    Ya they'll fit and then some. Check my pics. Mine is 9" lift and it clears the 38s just fine. Backspacing of your rims might make them rub but I doubt it. I can flex, turn lock-to-lock, etc without ever rubbing them.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    hog out your fender and add a 2" body lift. once you get to 3in it tends to get a bit squirrely, FWIW.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't waste the time doing a 2" body. Go 3" or not at all.
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    ran 9" of lift and 38's for two years cleared quite well
