Will 4 inch shocks fit 5 inch lift??
Discussion in 'The Garage' started by 88k5canyon, Dec 1, 2002.
  1. 88k5canyon
    88k5canyon Registered Member
    Jun 19, 2002
    27
    Layton, Utah
    I am planning on getting new pro-comp shocks this month but as of now only have four inches of lift but plan to use zero rates to get another inch will these "4 inch lift" shocks fit my hopefully 5 inch configuration down the road?
    David
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Sure they will fit. But plan on buying a bushell basket full of left rear shockmounts, because you will tear them off without wheeling.
    The only way to honestley answer your question will be to check the drop and compression of your suspension in relation to the compression and extension of your shocks.
  3. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Fred is right. In my experience most shocks that come with 4" kits are too short already. The shocks that came with my buddy's 4" pro-comp kit were fully extended at ride height up front. I guess smoking crack and designing lift kits for the masses goes hand in hand./forums/images/graemlins/angryfire.gif
    Rene
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    id go with a 6 inch lift shock.then at least you will have the extra travel you need and wont have to worry about it.
  5. BlazinNewTrails
    BlazinNewTrails Registered Member
    Sep 20, 2002
    48
    washington state
    When I went from 2 1/2" to a 4" lift I asked the guy at 4wpw if I needed new shocks (I've got Rancho 5000's from the 2 1/2" Rancho kit) To my surprise he said no. He said that the 2 1/2" and 4" kits use the same shocks.
    I would go with a 5-6" lift shock in your case if it were me just to be safe.
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    The RS5000's I bought are supposed to fit with 4-6" of lift.
  7. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    yup...just because they say it's meant for 'X' lift doesn't mean they are long enough. It just means that's what you'd get with that kit. Better to cross the truck up on a ramp and measure the extremes to calculate optimal shock length.
    Rene
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I was thinking of a 4in lift also and though of one day doing the same with zero rates will having 6in lift shocks mess anything up if its on a 4 in lift?
