Will 454 TBI unit adapt electronics to 350 TBI truck?
Discussion in 'The Garage' started by BigBurban350, Dec 12, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Exactly.
    Oh another question. Can I get a 4 barrel carb intake(edlebrock performer) and use an adapter plate to which ever TBI unit? Or will that cause a big headache trying to get it running?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    1. Yes. 2. My 87 454 came from the factory with a TBI to spread bore adapter. 3. No, but I think you need to use the 350 injectors, though. /forums/images/graemlins/thumb.gif
  3. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Do I have to change injectors if I am running a 388 small block? Ported heads, headers, probaby run a performer intake.
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    It probbly would run rich without an injector change. I was going to get a set of injectors out of a 366 truck engine. I figure they would probably give you about the right amount of feul for a 383.
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    It's my understanding that the only diffenec between the BBC & the SBC TBI systems is the injectors and the computer prom. Can any verify or correct this?
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I would run 65 lb hr injectors on a 383.
    turbocity .com makes the adapter plates you are looking for
    The only diference to hook up a 454 TBI to 350 system in electrinics is the prom chip and the IAC wireing. You can get an adapter for the IAC from turbocity also. Other wise everything else will plug right in.
    If you do any mods to increase the air flow you will need an adjustable fuel pressure regulator and probabally a custom chip.
  7. BigBurban350
    Jun 9, 2002
    711
    Michigan
    So you saying I would just need to get a computer from a vehicle that had a bbc TBI?
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The TB is different, 454 model has larger bores and injectors. Stock 454 uses a spreadbore intake with an adapter.
