Will 5-5.5" of lift clear 35x12.5" tires with no trimming?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85scottsdale, Jan 19, 2004.
  1. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Will 5-5.5\" of lift clear 35x12.5\" tires with no trimming?
    I'm hoping to get some 35x12.5" tires under my K10 without trimming the feners, i'll be installing a 4" lift and may put some 1" zero rates in the front and build some 1" longer shackles to get another 1.5" on top of the 4". And then 1.5" blocks in the rear. Or should I just put a 2" body lift on it and be done? With the body lift I won't have to worry about my driveshafts hopefully and it should clear the 35x12.5" tires on 15x8s with 3.75" backspacing with no trimming. What do you guys think? I know somebody has done it.
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Re: Will 5-5.5\" of lift clear 35x12.5\" tires with no trimming?
    The tires will rub with the suspention only lift. Mine does.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    yes it will..
    i run 33x12.50 on 15x10s with no lift at all, and the tires dont rub at all, not at full stuff with the wheel cranked even..
    in this next one.. look at the spring arch, you can see a little of it in front of the tire..
    there ya go.. so you have a 2" taller tire, no wider and 5" more lift.. it WILL FIT! /forums/images/graemlins/thumb.gif
  4. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I'm talking about 35's not 33's /forums/images/graemlins/thumb.gif
    But anyway, I do have a spare 35x12.5" tire I will be using as a spare and it will probably be mounted on a 15x10 since I have 8 of them around. Maybe I could have it mounted and stick it on and see what happens. I'm actually leaning more toward just the 4" suspension and 2" body right now.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think it will rub(but not to bad) but not too bad
    I usto run 2in and 33's and they rubed horibly when I Flexed with 33 12.50 15's /forums/images/graemlins/thumb.gif
  6. Confedneck
    Nov 1, 2002
    5,236
    i know you're talking 35s.. which means you have 1" larger at each end tire.. with 5" more lift.. i bet you'll be FINE..
  7. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Yeah, and it will probably turn out close to 5.5" even. But i'm a bit worried about my driveshafts after that, i'm thinking the tires will fit and maybe rub a little stuffed and cranked, but its just sheet-metal /forums/images/graemlins/grin.gif . Anyway, then if I go to 5.5" of lift what do I need to do with my driveshafts?
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] When I put in the 6" lift on my K5, I had new drive shafts made. It's not that expencive, and I ended up with all new parts. /forums/images/graemlins/thumb.gif
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Well maybe........................
  10. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    What does "well maybe..." mean? /forums/images/graemlins/thinking.gif
    Are those 35's in your picture? That doesn't look like even 4" of lift. So I assume your saying it will work?
  11. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Yup, those are 35's and that's not even 2" of lift, that's 16 year old stock springs pimping a big 620 or was it a 648 on the RTI ramp, sway bar connected and no rubbing............. /forums/images/graemlins/thumb.gif
  12. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I have had lots of people tell me 35's will fit under 4" of lift with no rubbing. I think their all right especially since they will be 12.5" wide tires on 15x8 wheels with atleast 3.75" backspacing.
  13. the_goat
    the_goat 1/2 ton status
    Sep 13, 2003
    113
    Phoenix, AZ
    Mine rub a bit with 35's and a 6 inch lift.
    John
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think they'll fit with NO rubbing. Mine didn't fit on the 8 or 10 inch wheels I ran them on with a stiff ass 4" setup and the swaybar connected, doubt yours will.
    Sawzall is the best mod I've made yet. It gets addicting though, you won't want to stop.
  15. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    My wheelin bud has a k10 with 6" superlift and 35x12.50s on 15x10s and it only rubs slightly when its articulated to the point of insanity!
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think that's basically it. You've got to flex it pretty far to make them hit with 6". It can be done, it's not impossible, but it's not common that it go that far either.
    Disconnecting the swaybar is a good way to allow that.
    If you're that worried and you don't want to trim, just lower your bumpstops.
  17. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I could rub a 33 with a 4" lift and the swaybar attatched. The 35's were worse, and the 37's with no swaybar sound funny. (rubbing the body is funny to me /forums/images/graemlins/rotfl.gif)
  18. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    There are a lot of factors to consider....the biggest being that every truck, lift kit, and tire/wheel combo is a little different. On my '90 K5 I ran 32x11.50's on 15x10 rims with no lift and no rubbing...on the street, never did any real off-road stuff with that setup.
    With 33x12.50's on the 15x10 rims, a 4" lift with the swaybar disconnected, I could get it to slightly rub when seriously twisted on the trail.
    35x12.50's with the same rims and lift required moderate trimming.
    I now run 38x13 Swampers with the same lift and they fit with no rubbing, but the fenders are obviously trimmed quite a bit.
    Adding more lift will only get you so much tire clearance because the wheelwell openings are only so wide. Without fender trimming I would probably still rub the 38's with 10" of lift.....
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have 9" and 38.5x16s and I manged to make them destroy the fenders even with the swaybar connected. That's when I finally started to trim, at which time I went overboard, and now I'm losing my body lift as I think I can make it at 6".
    I believe this is the only pre-trimming with the 38s image of my truck that shows anything at all.
  20. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I'm thinking about getting a sway bar disconnect kit from ORD so the front will probably flex a good bit. I may be willing to trim some just long as it isn't excessive. If its gonna be a real wheeler I feel that is its fate anyway. Besides new fenders are only about 100 bucks anywa /forums/images/graemlins/grin.gif I doubt I will need to trim the rear at all, just some minor trimming around the bottom of the fronts, since thats where it seems like it may rub when I have the wheel turned.
