Will 6" lfit work for 35's on a 15x12 rim
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by jamesjones, Jul 26, 2003.
  1. jamesjones
    jamesjones Registered Member
    Apr 28, 2003
    11
    San Diego, CA
    Will 6\" lfit work for 35\'s on a 15x12 rim
    After doing some searches it seems like everyone has recommended a 6" lift to run 35's. Most of them though, have been on 8" or 10" wide rims. I plan on going with 15x12 on my K5 as it will be seeing mostly sand and pavement. Do you still think I'll be ok with 6" of lift or should I consider going with 8"? Any inf would be greatly appreciated.
    James
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Re: Will 6\" lfit work for 35\'s on a 15x12 rim
    How wide is the tire (12.50"?) and how much backspacing on the wheels you want?
  3. jamesjones
    Apr 28, 2003
    11
    San Diego, CA
    Yeah, the tires will be 12.5. As far as backspacing, I can't remember the exact specifications but I plan on running Weld Typhoons.
    James
  4. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I have a 6" lift with 35's (12.50) and it is just fine. I think my rims are 10" though. How agressive of a tread are you looking at. You may have some minor rubbing if you go with something like Swampers.
  5. jamesjones
    Apr 28, 2003
    11
    San Diego, CA
    I was planning on going with some TRXUS A/T Radials but I was also considering TSL Radials. Thanks for the info.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think a 12.5" tire on a 12" wide rim is just too wide.
    I think my 36x12.5 TSL's (that actually measure 13.5" wide) too narrow for my 10" wide wheels.
    If you are looking for a sand tire stay away from swampers!
    They will just dig to china! I would look into the new TrXus STS by Interco.
  7. joryyroj
    joryyroj Registered Member
    Mar 13, 2003
    32
    Wylie Texas
    May not be much help to you, but I am running 4" lift and 35x12.5 15s on 10x15 wheel. I tried a 10x12 wheel and they didnt rub, but they were really close to the front fender when I turned sharp. I wasnt able to even slide my finger between the wheel and the fender. The back was no difference though. Sorry wasnt more help.
  8. jamesjones
    Apr 28, 2003
    11
    San Diego, CA
    Thanks, that's actually a lot of help. I'm thinking the 6" lift is going to be ok. As far as running a 12.5 tire on a 12 wheel, I think it looks great. That's the main reason I'm going with a 15x12, it looks tough. I ran 35x12.5 BFG AT's on 15x12 Alcoas on my Dodge Ram and also on my 2nd gen without a problem so it should be ok. Over in Arizona I've seen guys run 33x12.5's on 15x14 wheels on Jeeps before /forums/images/graemlins/ooo.gif lol now that's pushing it. Thanks for the input.
    James
  9. Big Sean E
    Big Sean E Registered Member
    Mar 29, 2003
    52
    Boston, Massapoopits
    When you get a chance, could you show some pics of those wheel and tire combos?
  10. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I find 6" to be a bit too tight with my 15" BFGs and 15x10 rims. every so often the tire grabs the inner fender and pulls it into the wheel well, but only when really twisted. I might be able to get away with a longer shackle or zero rates to clear it since it is so close to fitting.
