WIll 81-87 door panels fit on a 73-80 door?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 7, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I found a good deal on door panels, but they are intended for 81-87 Silverados.
    My doors are the 73-80 type.
    I know the whole door from a 81-87 wil bolt onto the earlier cabs, but is the door panel different?
    I have manual windows and manual door locks.
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    They will fit..... The only problem is the door handle will need to be trimed out or get the inside handles for a newer rig....
    C'moe
    Kill Roy was here!
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    73-75 door panels are square on the top. I got some sweet 77 door panels at a junkyard once and went to put them on and they DO NOT fit. They curved up at the top. So if you have the early doors, then they wouldn't work...but if you have post 76, then you should be OK.
    '73 K5
    Chevy good...Ford bad
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Sure will...changed my 79's interior over to the 90's gray with an 81 up dash pad and 83 bezel. Had to use the late model inner door handles though so they fit the bezels on the late sytle.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
