Will '90 van steering column fit on 85 Sub?
Discussion in 'The Garage' started by dapert, Oct 16, 2005.
  1. dapert
    dapert Registered Member
    Jun 10, 2003
    12
    Visually they look the same but does anyone know for sure it the steering column from a 1990 GMC van would fit on a 1985 Suburban?
  2. dyeager535
    26,979
    Really really doubt it.
    No exhaustive database I'm aware of regarding column interchange, but in short the different vehicles used different length columns in all applications, although the non-length critical parts are essentially unchanged between them.
    Distance of the dash to the steering wheel and distance from firewall to column mounting point in the dash are two measurements could foil a swap.
