Will a 10bolt yoke and D60 Yoke Swap?
Discussion in 'The Garage' started by BigCountryx, Aug 3, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Just what the title asks, Will a standard D60 Yoke work on a 10 bolt and vise versa? (Front axles)
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    They use the same ujoints but the yokes are totally different
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Are the splines on the pinion and the diameter of the yoke where it meets the pinion seal the same?
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    The pinion diameters are the same according to Richmond. They are both 1.626". But the 10 bolt has a 30 spline pinion whereas the 60 has a 29. You could try and see if they will interchange. One area where you'll run into a problem is the seal area.
