Will a 2wd 14 FF work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Feb 8, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    so will it? or will a dana 60/70 from a 2wd work as well
    Thanks Dan
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, 2WD/4WD were the same for the most part. I think there are different shock locations though, depending on the year. That's the only diffs I know of.
    Oh, and the 70s (as far as I know) came only on duallys so they would be too wide. Just like the one I mentioned to you that the guy in LasVegas had. Not sure about 60s. Seems like I recall them being on single wheels.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.<P ID="edit"><FONT class="small">Edited by BadDog on 02/08/02 07:36 PM.</FONT></P>
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    when i called the junkyard today about a 14 (my cousin owns it) he asked what i was doing, and said that any of the ones from a chevy durring the right years (cant remember which) would work
    but i have gotten bad info before
    are you wanting it for your K5?
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thanks thats what I needed to know. I will be 1 ton soon !!!!!
  5. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I used a 14FF from a 1980 Chevy 2WD in my 75 K5. It was a direct bolt in with no modifications.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I had to mow off the shock mounts and sew on the ones from my 12 bolt.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  7. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I'm running a 2wd housing out of a '75. I had a '77 4wd housing but the threads on the spindle drivers side were chewed up abit. The only difference was the shock mounts length, they hang down lower about 1 1/4". But the location is the same. Oh these were both out of a 3/4 ton. The 1 ton mounts are just the opposite on location. drivers side mount is on the front of axle, and pass side is on the rear. Just the opposite of your 10 or 12 bolt or the 3/4 ton. Hope this helps.
    Later Ed
    I'm not tail gating. I'm DRAFTING.
