Will a 32-spline 208 from a 465 fit behind a 205 version Turbo 400?
Discussion in 'The Garage' started by HarryH3, Jun 27, 2004.
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a line on an NP 208 that was originally installed behind a 32-spline 465. My current setup is a Turbo 400/NP 205 that came from a 1980 K30 pickup. I'd like to try out the 208 in place of the 205 to get the better low range gear ratio. But will it fit without a lot of hassle (and cost)? /forums/images/graemlins/eek.gif Isn't there some oddity with the Turbo 400's having various length output shafts, depending on what t-case was installed behind them? I have no interest in yanking the transmission, so if that what it takes then I'll just skip this little mod. But if it's a fairly easy swap, then I may give it a try (once I find an adapter). /forums/images/graemlins/thumb.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    AFAIK, it will fit but you will need a longer output shaft.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Harry, I think all 4WD TH400's are all the same. The 208 from the 465 might be different, but I don't know. Check with Mark (Burblover), he mentioned to me a while back having a TH400 version 208 and adapter. He might want to sell it or at least you can look to see if it may be the same as your current setup. /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I believe the ouput shaft would be the incorrect length. I don't know for sure but every 400 tranny that I have has a different output shaft length. The only one I don't have is the 205 version so I can't check.
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmmm, so the answer is "yes" and "maybe"? /forums/images/graemlins/thinking.gif /forums/images/graemlins/wink.gif
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    It'll fit.... Long as you got the adapter that goes w/ the T400.
    I just did this to an 81 'Burb I've got. It came w/ a T400 and a blown 208. I installed a good 208 that came from behind a 465. Staight swap!/forums/images/graemlins/waytogo.gif
    Marv
    **edited** ooh... er... /forums/images/graemlins/ignore.gif I just re-read your post. I see that you got a trans issue **maybe**...
    Marv
  7. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    tranny output shaft length is different. the th400 for np208 shaft is 32 spline and sticks out 2.5". the np205 version th400 has 32 spline shaft that sticks out 4.5".i know the np208 for the 700r4 has a 27 spline input so i would guess that the sm465 one does also! seems like almost every different tranny-transfercase combo used different shaft lenght and adapters. i say save up for a doubler! you already have the beefiest tranny and tcase just find the correct np203 that matches the combo you have and your are set. offroad design has alot of info on tranny output shaft lengthes adapters and other stuff on the doubler page. /forums/images/graemlins/rotfl.gif
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Thanks for the info! The later model 465's have a 32-spline output shaft that matches the Turbo 400. But it sounds like my 400 has an output shaft that is far too long for the 208 to mate with. /forums/images/graemlins/frown.gif
    The doubler is way too much time, cash, and effort for what I use this truck for. I mainly want to be able to keep the speed low when coming down steep, loose, rocky trails. Right now that requires lots of feathering of the brake pedal. /forums/images/graemlins/eek.gif I guess I may end up swapping in the 700R4 and 208 that I have in the garage. /forums/images/graemlins/thinking.gif
