Will a 4.3L starter fit on a 350?
Discussion in 'The Garage' started by 8_YOUR_H2, Nov 25, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    My starter is fried and one of my friends has a 4.3 starter layin around. Any one know if it will work on a 350? Are the teeth and mounting holes the same?
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    if they both have the same size flywheel (153 or 168 tooth) then the answer is, usually. Most 4.3's are 168tooth flywheels, since they were only really put in small trucks.
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
  4. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Since I've had smallblock starters that don't fit other smallblocks, I'll never just say the answer is 'yes'. the answer is most likely, but try it before you buy it =)
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I am having a lot of the same problems as in the other mentioned post. With the exception of a loud banging sound that happens with the distributor on.
    It is weird though. I have started it and ran it 4-5 times so far....
